Vecchio 01-03-09, 08:50 PM   #1
ENEA
predefinito Jamara x2 cr-pro competition.
Che ne pensate di questo modello :
Jamara - Hong Nor X2-CR Pro Racing Buggy
Description
JAMARA-HONG NOR X2-CR PRO PERFORMANCE 1/8TH SCALE NITRO RACING BUGGY
The new Hong Nor X2-CR Competition Pro Racing Buggy is almost here, we are expecting them to land with us at SMD at back end of January 2009 in good time for the new season.
Some well thought out re-designing of the chassis and several other key areas have taken place to give a much better performing racing buggy without sacrificing durability. Taylor James clearly proved its worth at this years Worlds warm up at The Farm II in USA with fastest recorded single lap & TQ & Win over the best drivers in the World.
Specifications:
Lower Gear Reduction for Front and Rear
Helical Cut Crown Wheel and Pinion
4mm Carbon Fiber Front Shock Tower
4mm Carbon Fiber Rear Shock Tower
Two Piece Center Diff. Mount
Carbon Fiber Center Diff. Mount Plate
Lightweight Small Diameter Center Spur Gea
17T Vented Clutch Bell
Lightweight Drive Cup for Pinion Gear
Lightweight Out Drives for Differentials
CNC Machined 7075-T6 Alumunum Center Drive Shafts (Hard-Coated)
CNC Machined 6061-T6 Aluminum Shock Posts ( Hard-Coated).
CNC Machined 7075-T6 Lightweight Chassis (Hard-Coated)
Servo Saver Connecting Plate (Hard-Coated)
CNC Machined 7075 Front Lower Arm Holder (Hard-Coated)
CNC machined 7075 Rear Lower Arm Holder (Hard-Coated)
CNC Machined 7075-T6 Center Drive Shaft for Front and Rear
Screw Type, Captured Hinge Pins
Top Loading Servo Saver
16mm Super Big Bore Shocks
Servo Saver Aluminum Tube (Hard-Coated)
Carbon Fiber RadioTray
Carbon Fiber Front Plate
CNC Machined 7075 Steering Knuckle Arm-L&R (Hard-coated)
Universal Joint, (Front and Rear)
35mm 3 Pin Flywheel
Low Profile Engine Mount (Hard-Coated)
CNC Machined Rear Toe-in Plate-2.5 Degree (Hard-Coated)
CNC Machined 7075, Hard-Coated Center Chassis Brace (Front &Rear)
Lightened Aluminum Long Life Clutch Shoes (Silver)
High Down Force Wing
Super Lightweight Dish Wheels
Technical Data:
Length: 490mm
Width: 308mm
Wheelbase: 323mm-328mm
Front Toe In: Adjustable
Rear Toe In: 1-3 degree Changable
Spur Gear: 44T
Ground Clearance: Front 57mm & Rear 70mm
Weight: 3350 grams (Including Radio & Engine)
Ultima modifica di ENEA; 01-03-09 a 11:22 PM
Vecchio 01-03-09, 10:34 PM   #2
L'avatar di mikeleamigoni
residenza: bergamo!
mikeleamigoni è un newbie...
Invia un messaggio tremite MSN a mikeleamigoni
quanto costa??
Xx... Amigù ...xX
BRUSA 7.5 RACING TEAM = io due mitike kyosho 7,5 e dipydavide un mitiko amico
mikeleamigoni non è in linea   Rispondi quotando
Vecchio 01-03-09, 11:21 PM   #3
ENEA
Originariamente inviata da mikeleamigoni Visualizza il messaggio
quanto costa??
Purtroppo non sono riuscito a trovare il prezzo sul sito tedesco.
Ultima modifica di ENEA; 03-03-09 a 04:58 PM
Vecchio 03-03-09, 05:06 PM   #4
ENEA
Qualche garetta :
Andalucia Regional Race
HongNor reports - “The Andalucia Regional Race was held in Alhaurin de la Torre this past weekend. This race is a Warm Up of the Spanish championship race which will take place at the same track in 3 weeks. Saturday the qualification was reduced due to heavy rain and HongNor team driver Richi Gomez finished as 3rd qualifier. On Sunday Richi finished first at Semifinal. He was more than one lap ahead of the second driver. During the main Final, he was leading the race until half way through the final. Because he faced a plug failure, he lost many lap time. Richi could only recover to a fantastic 3rd place when he finished the race. His car and Engine were fantastic all weekend and everyone at the track recognized his superiority in jumps and bumpy areas.
Podium:
1) Angel Roque
2) Miguel Martin
3) RICHI GOMEZ — HONGNOR X2 — PICCO P7 — RUNNER TIME
8 ) EDUARDO PUYANA — HONGNOR X2
11) TEO GARCIA SIERRA — HONGNOR X2″
Andalucia Championship
Farmelo Portelli Wins Gozo Regional Championship Series 2007
South East Regional Series 2008
HongNor Won Regional Championshp in Spain
Vecchio 03-03-09, 05:11 PM   #5
L'avatar di TONYM73
Registrato dal: Jun 2007
residenza: Cagliari
A prescindere dalle prestazioni,questa macchina non mi ha mai attirato più di tanto..Comunque in pista si comporta egregiamente.
Vecchio 03-03-09, 05:18 PM   #6
ENEA
Ma come modello oppure marca?
Vecchio 03-03-09, 05:26 PM   #7
L'avatar di TONYM73
residenza: Cagliari
Originariamente inviata da ENEA Visualizza il messaggio
Come marca.
Gia il fatto che una macchina abbia diversi "padri",e sia marcata Hong Nor,Jamara ecc ecc (dietro c'è anche la Carson Modelsport),mi fa pensare ad un prodotto commerciale senza arte ne parte,e non scatta in me quel coinvolgimento psicologico che ci spinge a fare una scelta piuttosto che un'altra.
Parere personale.
Vecchio 04-03-09, 10:12 AM   #8
ENEA
Non piacerà ma ha vinto anche in Sud Africa :
HongNor reports - “Hong Nor team driver Mark Remken converted the X1X-CR pro that was sponsored by HONG NOR to the X2. Hobby Centre sponsored Mark with the X2 conversion kit. The comments from Mark after his win were, “the car is a big improvement over the X1. It jumps better, corners better and accelerates better.” The other competitors using the X2 were happy that the lap times had improved. Gary MCDonogh, the SA HONG NOR DISTRIBUTOR, stated that “the new gear ratio means that a 15T-18T clutchbell can be used, and this allows much better fine tuning of the engine to track conditions.” Congratulations on your win Mark!” [Our thanks go to HongNor for this news]
Related News:- RC Pro South Africa
Vecchio 04-03-09, 10:20 AM   #9
ENEA
predefinito News
Qui invece è arrivata solo seconda
Hong Nor reports - “This past weekend also took place the 1st race of the CATALUÑA CHAMPIONSHIP at Ripoll (Girona) track. With topl drivers like Robert Batlle, two HONGNOR X2-CR drivers finished on the podium. ALVERT NAVARRO & PATXI PEÑAS. During qualification Patxi Peñas with Hongnor and Picco had very bad luck and needed to recover from the 1/8 to semifinal. The semifinal was very intense betwen Robert Batlle and Patxi Peñas. During the final both Alvert and Patxi were fighting for the victory with Robert Batlle during the entire race. Thirty minutes through the final, Alvert had a problem with a tire and lost some time so he finished 3rd. Patxi fought until the end and managed to finish 2nd. Congratulations to Alvert Navarro and Patxi Peñas for they both finished on the podium. There are a total of four new Hongnor X2-CR in the main final!
1º Robert Batlle — ASSO — GRP
2º PATXI PEÑAS — HONGNOR X2 — PICCO P7
3º ALVERT NAVARRO — HONGNOR X2″
Related News:- Ibiza Championship Results
1/8 Off-Road European Championship Race Report
T2′007 Wins MuchMore TC Championship
Balear Championship
Vecchio 04-03-09, 10:26 AM   #10
L'avatar di TONYM73
residenza: Cagliari
Per quanto riguarda le vittorie,un buon assetto,una buona meccanica e sopratutto un gran manico può portare nel podio qualsiasi macchina.Senza tralasciare il fattore culo.
Parere personale: se me la regalassero la rivenderei subito.
Vecchio 04-03-09, 10:32 AM   #11
ENEA
Se te la regalassero, la regali a me, naturalmente le spese di spedizione a carico mio
Vecchio 04-03-09, 10:34 AM   #12
L'avatar di TONYM73
residenza: Cagliari
Ok,allora d'accordo: però ricorda che sta sempre dietro alla S3
Jamara gtp iceman0182 Automodelli a scoppio 1/8 Rally Game 5 23-02-08 10:23 PM
Jamara Macho nico_ch Automodelli a scoppio Monster Truck 2 23-06-06 07:45 PM
Jamara Macho mt clax797 Automodelli a scoppio Monster Truck 1 05-10-05 09:17 PM
macho jamara titanox Automodelli a scoppio Monster Truck 3 08-04-05 10:15 AM
Tutti gli orari sono GMT +2. Attualmente sono le 07:22 PM.
