Vecchio 10-12-09, 07:56 AM   #1
Registrato dal: Dec 2009
residenza: SAN LUIS POTOSI, MEXICO
ALEX GAROLI è un newbie...
predefinito [MOTO] Ducati 999 "MONOBRAZO"
Hi there, this is my new proyect, a New-Ray 1/12 Ducati 999:
I found this picture in internet and I inmediatelly wanted to tune my bike.
But later I tought I can do better, changin the regular swing arm to a single sided one, and more agressive paint:
Im going to use a part of the fairing from a Ducati Supersport 1000, because the 999 fairing is too flat:
I allready made the sketches of the single sided arm and the necesary modifications, because the rear brake and traction, I havent decide if use a tubular swing arm or monocoque tipe, I have to bend the rim spokes to fit the new swing arm:
This is the frame anf fork:
These are the parts to modify:
I saw a sketch from when ducati was planning to release the sport classic concepts, like paul smart replica:
And Im thinking in paint the bike like that, I dont know yet.
Here is my sketch:
I allready made the main arm:
It came from a broken sunglasses, I liked the oval shape:
Next step is to cut the swing arm:
ALEX GAROLI non è in linea   Rispondi quotando
Vecchio 10-12-09, 07:59 AM   #2
The technique for bending the rim consit in use a lighter, make circular movement under the rim, and then press it against an objet that has the distance I need to bend:
There it is, a rim for single sided arm:
And a quick check out:
Next step is to complete the swinr arm structure, it is similar to the ducati mh900e and monster st4:
Here in mexico is hard to fin materials, so I have to use anything, to get a thin tubing, I got it from a candy:
Here is the rear view:
I added primer to find imperfections, I havent decided if paint it yellow or the paul smart version:
Next, I cutted of the bottom of the fairing, now I have to make the parts fit:
To paste really hard two pieces, I use krazy and sodium bicarbonate, it makes a really strong union ans is sandable:
Here is the two parts glued and with primer, the union was perfect:
And here is with the ducati yellow:
Icutted off 3mm to the forks to maka the front end lower:
Here are the basic paint pattern:
The bike getting togheter again:
I added a anti heat cover made with thin aluminum sheet:
Vecchio 10-12-09, 08:00 AM   #3
Here are the parts with grille inserts:
Really close to the sketch:
More pictures:
Desmosedici type exhaust pipes:
Radiator grille:
The monoarm:
With her original sister:
And more pictures:
Another unique model for my shelves!
Vecchio 10-12-09, 09:32 AM   #4
wow you are the Mexican version of our "Ditraverso", also him likes to modify and invent new bikes versions
Take a look on its gallery ditraverso's Gallery
Ciao ciao
Vecchio 10-12-09, 09:46 AM   #5
L'avatar di gionc
Registrato dal: Dec 2005
Welcome aboard Alex.
Feel free (read.... you must.. ) to post smaller images, it's quite tricky browse the wip so....
Vecchio 10-12-09, 10:03 PM   #6
L'avatar di bootsy
Registrato dal: Apr 2003
residenza: Lainate (MI)
bootsy inizia ad ingranare.
I agree with Gionc. It takes a lot for those who hasn't a fast connection to open your wips.
PS: your choice of sunglasses and other simple objects to improve your models in great!
[MOTO] Ducati 999 "Imola" ALEX GAROLI Statico Work in Progress 15 10-12-09 09:58 PM
""Dubbi"" costruzione mini rc hobby & work edicola bubino83 Comunicazioni e presentazioni 1 01-12-09 01:17 AM
Yamaha M1 2009 Livree "Spies" e "Punto Evo" ez9 Statico Reference 0 30-11-09 12:09 PM
[Aereo] Mitsubishi A6M3 "Zero" e Nakajima Ki-84 "Frank" ring Statico Work in Progress 18 03-05-07 10:48 AM
"WIP" Toyota Corolla Memorial Bettega - Motorshow 2001 "Cantamessa" buddha77 Statico Work in Progress 7 12-12-05 01:06 PM
Tutti gli orari sono GMT +2. Attualmente sono le 04:41 PM.
