Vecchio 25-06-08, 03:29 PM   #1
L'avatar di gionc
Registrato dal: Dec 2005
predefinito modellismo statico dinamico :D
Guardate che ha combinato un'amico, Steve, dalla Polonia:
gravestory_01_0001.flv - Video - Photobucket - Video and Image Hosting
Vecchio 25-06-08, 03:59 PM   #2
L'avatar di lapo
residenza: Firenze
lapo inizia ad ingranare.
Ma cosa aveva da mangiare fritz? senape? Fossi in lui mi farei fare un attento esame delle feci...
Vecchio 25-06-08, 09:28 PM   #3
carino.....
ma che ha usato per la neve così "corposa"?Di solito nei diorami è molto più piatta......
Comunque è suonato un tot anche lui..Scommetto che siete amici...
Vecchio 25-06-08, 11:44 PM   #4
L'avatar di gionc
Steve: I'm sure you're lurking LOL,
Mr. Patacca man (above) would know how did you made a snow so "real", he said also you're nut (or better he said literaly offbeat ROFL), oh well you understood by yourside Lapo's moustard gag
Vecchio 27-06-08, 12:05 PM   #5
L'avatar di gionc
carino.....
Ecco la risposta di Steve che dal cambio del format non riesce a loggarsi: tenterò un succinto riassunto in ita
"I used a mixture of white glue and water and microballons with one drop of light blue Vallaejo acrylic added (not sure if the paint made any difference to the color or not LOL)
mixed the glue 50/50 with water and paint first in a plastic cup and then added a load of microballoons. This mix is very thick and no good to use so then you start adding more water and mixing until you get a good consitency to so that it settles smooth but holds shape. I put it on the dio with a plastic spoon and spread gently where necessary with a little artist spatula. A wet spatula molds it very well without leaving marks.
Finally when everything was done to my liking, I "dusted" everything with a VERY light dust of pure microballons from a spoon held 10cms above the dio.
It is worth knowing that I took some of the basic mix to make small ammounts of thicker snow for the pillars (so it didn't flow too much) and added more water to make it flow better into corners.
Here are the links to photobucket pictures of the microballoons
http://i6.photobucket.com/albums/y24...terials_01.jpg
http://i6.photobucket.com/albums/y24...terials_02.jpg
Ha usato un mix di colla bianca, acqua e microballons (vedi foto), più una goccia di Vallejo blu chiaro: cominciando da 50% colla+50 acqua ed una manciata di microballs, ha quindi continuato a diluire finchè il composto si presentava morbido pur tenendo la forma.
Ha distribuito il composta con una spugna di plastica e dove necessario con una spatoletta per artisti: raccomanda una spatola bagnata utile allo scopo senza lasciare segni.
Quando il risultato è stato di suo gradimento ha cosparso il "gel" con microballs pure, con una spugna da 10 cm di altezza. Se non interpreto male consiglia di parzializzare un pò il composto orginale in angoli particolari per limitare l'eccesso ed usare un composto un pò più diluito che evidenzi gli angoli.
bello però! sto pensando a montecarlo.... se solo gli assetti da ghiaccio fossero più carucci....
Vecchio 27-06-08, 12:12 PM   #6
Ed ora sotto con qualche bel diorama di un Montecarlo d'altri tempi o del rally di Svezia
Ciao ciao
Vecchio 27-06-08, 12:55 PM   #7
Mr. PATACCA?
Vecchio 27-06-08, 01:18 PM   #8
L'avatar di gionc
Mr. PATACCA?
MrPatacca man per esser precisi, suona bene no? Potresti loggarti su AF anzi petta che te lo creo io
Vecchio 27-06-08, 01:37 PM   #9
L'avatar di cappy
Registrato dal: Mar 2007
residenza: Termoli
cappy è un newbie...
Invia un messaggio tremite MSN a cappy
poteva ricoprire con un po di neve
Saluts
Fatti non foste a viver come bruti ma per seguir virtute e conoscenza...
Di tutta l'erba non fumate solo un fascio
cappy non è in linea   Rispondi quotando
Offerte Modellismo dinamico su Ebay vituperio Aeromodelli 13 02-10-07 12:25 AM
Srivere le date delle gare di modellismo dinamico eddythebest Automodelli a scoppio Monster Truck 1 25-06-07 11:46 PM
Rendi piu' dinamico il tuo sito... inserisci le news di Modellismo.it gnanni Comunicazioni e presentazioni 3 12-01-07 10:28 AM
Accessori modellismo statico... sampei2000 Statico - Kits, Info e Varie 2 30-12-05 03:37 PM
modellismo statico: tabù... icemankimi Statico - Kits, Info e Varie 6 11-02-05 10:33 PM
Tutti gli orari sono GMT +2. Attualmente sono le 04:43 AM.
