Vecchio 09-05-12, 07:31 PM   #1
L'avatar di yyyManu96yyy
Registrato dal: Jun 2011
residenza: Casoria ( Na )
yyyManu96yyy ha avuto comportamenti non adeguati in passato...
predefinito problema Fail Safe con telecomando MAVERICK MTX-24
salve ragazzi, ho un problema nell'impostare il fail safe in frenata!!!
La radio, è un MAVERICK MTX-24 e la ricevente lo stesso... come posso impostare a mio piacere il fail safe?????
Ho provato a premere il bottone e cose così ... nessuna vite niente... Come caspita si impostaa?????????? Vi prego aiutatemi!
Lavora Sodo E Otterrai Ottimi Risultati Prima O Poi.... Un Sacrificio Oggi, Per Un Bene Domani!!!
yyyManu96yyy non è in linea   Rispondi quotando
Vecchio 09-05-12, 11:07 PM   #2
L'avatar di ufotecno
Registrato dal: Dec 2007
residenza: Vicenza
il manuale????
GRAZIE
Vecchio 10-05-12, 08:23 PM   #3
non c'è.. .-. ! altrimenti l'avrei visto no??!?!?!?!!
Vecchio 10-05-12, 08:48 PM   #4
residenza: Vicenza
Fail Safe Operation and Setup
The Receiver has a built in failsafe. The failsafe will automatically go to a pre set position if
• You lose radio signal/power runs out in transmitter
• If you suffer any interference
• If your receiver battery runs out of power
It is advised that you should set the failsafe so that in the event of any of the above situations the
throttle servo should apply brakes to your Nitro car or the throttle disengages to neutral on an
electronic speed control.
To set up your failsafe you must do the following.
• Turn on the transmitter and the receiver
• Set the steering and throttle trims to the neutral position.
• Press the “Fail Safe Set” button on the receiver. The LED will start to flash rapidly.
• While applying the desired amount of brakes/neutral on the transmitter (brakes for enine,
neutral for speed control) press the “Fail safe set” button. The LED will turn solid and the failsafe is set.
To check the failsafe is working you must turn on the R/C unit and then apply throttle with the transmitter. Whilst holding throttle turn off the
transmitter. The throttle servo or ESC should return to the pre-set position. This means the failsafe is working correctly. If your servo or ESC does
GRAZIE
Vecchio 10-05-12, 09:21 PM   #5
E' una buona guida, solo che a me il bottoncino del fail safe, sta solo sulla radio e non sulla ricevente e se lo premo, perdo il segnale !!! uffàà!!
Vecchio 12-05-12, 02:59 PM   #6
L'avatar di mirkorua
Registrato dal: Mar 2012
residenza: vicenza
mirkorua è un newbie...
Originariamente inviata da ufotecno Visualizza il messaggio
il manuale????
Ciao ti chiedo una Cosa ma il fail safe quando entra in funzione ?? Stamattina mi si sono scaricate le batt. " ricevente " e il fail safe non è intervenuto dovrebbe averlo fatto giusto ?? Ho una spektrum dx2s
Team xray xb9
SANWA MT4
NOVAROSSI PLUS21-4B
mirkorua non è in linea   Rispondi quotando
Vecchio 12-05-12, 07:23 PM   #7
residenza: Vicenza
il fail safe entra quando perdi il segnale, teoricamente con le batterie scariche dovresti aver perso il segnale e quindi dovrebbe essere entrato......pero non entra se la ricevente non riceve il giusto voltaggio, come ad esempio un crollo di tensione dovuto a una saldatura sul pacco che si rompe, un filo che si trancia, ci possono essere anche riceventi (ipotizzo) che non perdono il segnale anche se viene alimentata con pochi volt ma questi pochi volt non riescono a muovere i servi ecco che il fail safe non interverrebbe........
carica una volta in piu che una in meno............
GRAZIE
Vecchio 12-05-12, 08:03 PM   #8
residenza: vicenza
Ok grazie
Team xray xb9
SANWA MT4
NOVAROSSI PLUS21-4B
Problema funzionamento Fail Safe TastoDestro Impianti radio, servocomandi e avviatori 12 10-10-11 11:16 AM
problema fail safe tonyj Impianti radio, servocomandi e avviatori 19 25-08-10 08:26 AM
problema fail safe eu596 Impianti radio, servocomandi e avviatori 8 26-05-10 09:51 PM
problema fail safe vincmass Impianti radio, servocomandi e avviatori 6 13-03-09 08:53 PM
Problema Fail safe Spektrum DX3R Arthax69 Impianti radio, servocomandi e avviatori 0 21-02-09 07:13 PM
Tutti gli orari sono GMT +2. Attualmente sono le 10:54 PM.
