Vecchio 25-05-13, 07:13 PM   #1
L'avatar di one road one rc
Registrato dal: Apr 2012
residenza: Modigliana
one road one rc è un newbie...
Arrow Tekin RX8,Gen 2
FEATURES
Ultra-smooth and Precise Throttle and Braking Control
Compatible with Sensored/Sensorless Brushless and Brushed Motors
Easily Access Programming, Anywhere, Anytime
Datalogging Capability
High Voltage Programmable BEC
EZ Access HotWire Programming Port
HotWire PC Interface for Advanced Programming and Updating
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
Removable/Replaceable Cooling Fan
HDAC: High Density Copper PCB's
Sensor Plug for Precise Commutation with all Motors
Gold-plated Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™ Programming
One-Touch Radio Calibration
30mm RX8 Fan Included #TT3832 >>view image
High airflow volume for extreme cooling
Impact resistant durable design for offroad applications
Brushless Motor
PROGRAM FEATURES
High Voltage BEC (6.0v/7.4v)*
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (13 steps)
Timing Profiles (5 preset - 2 custom*)
Adjustable Throttle and Brake Minimums
Custom Throttle Curves
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, 4S, 5S, 6S, Custom)
Save, Load and Share custom ESC setup files*
Save, Load and Share Data Log files*
Extensive Tuning via Tekin HotWire PC Interface
*Requires HotWire Sold Separately
SPECS
Controls: Forward/Brake/Reverse
Input Voltage: 2S-6S Lipo
BEC: 6.0v / 7.4v 7amps
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Max Current: 220amps per phase
Timing Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5 x 2.2 x 1.4in (38 x 55.8 x 25.5mm)
Weight: 2.7oz / 76.5g
Tekin - RX8 1/8th Scale Brushless Systems
mmmm...interessante....chissà il prezzo...
one road one rc non è in linea   Rispondi quotando
Vecchio 25-05-13, 08:21 PM   #2
sirio76 diventerà qualcuno prima o dopo!
Online si trova a 150€+sped.+eventuale dogana. Io credo lo prenderò insieme ad altri amici, almeno così si dividono le spese di spedizione. Prima però aspetto i pareri dei colleghi oltreoceano e vediamo se c'è qualche magagna.. tanto è in backorder ovunque.. In Italia non so quanto verrà, a occhio direi sopra i 200€.
sirio76 non è in linea   Rispondi quotando
Vecchio 25-05-13, 08:31 PM   #3
L'avatar di franci98(2)
Registrato dal: Dec 2010
franci98(2) diventerà qualcuno prima o dopo!
Invia un messaggio tremite Skype a franci98(2)
Originariamente inviata da sirio76 Visualizza il messaggio
azz... beh non cosi "tanto" per essere appena uscito visto che volevo cambiare elettronica, potrebbe essere un'ottimissima alternativa
EDIT: ho trovato su amainhobbies, a quanto pare non esce prima di luglio... mmh...
Team Durango DEX408 (in vendita)
Sworkz S350 Be1 - LRP IX8 - LRP Dynamic 2200kv
Ultima modifica di franci98(2); 25-05-13 a 08:35 PM
franci98(2) non è in linea   Rispondi quotando
Vecchio 25-05-13, 08:42 PM   #4
solo?150?poco piu di un hw 150a!direi che potrebbe essere una alternativa se vendo i miei 2hw.....
vediamo cosa dicono gli "specialisti"americani di rc-tech....
Vecchio 25-05-13, 08:48 PM   #5
Beh si, 150.. anche dividendosi la spedizione devi comunque mettere in conto la dogana(che a volte si sfanga ma non sempre). Su altri siti lo trovi a meno e prima
Vecchio 25-05-13, 08:50 PM   #6
se ti scoccia scriverlo qui, scrivimelo in mp non mi faccio problemi
la spedizione però da amainhobbies la danno gratuita per questo tekin
Vecchio 25-05-13, 09:44 PM   #7
Si, la danno gratuita se abiti negli USA oggi come oggi lo prenderei da stormer hobbies, appena raggiungerà tutti gli altri negozi potrebbe convenire comperare da qualche negozietto ebay per evitare ulteriori tasse.
Vecchio 25-05-13, 09:51 PM   #8
Originariamente inviata da franci98(2) Visualizza il messaggio
Negli USA la posizione del mese e del giorno è invertita rispetto a noi, quando leggi 6-7-2013 vuol dire che esce ad inizio giugno. Sono comunque date stimate, non certe.
Vecchio 25-05-13, 10:48 PM   #9
Figurati che rinco**ionito che sono me ne ero scordato!
Buono, probabilmente nel mio carrello
Voglia di tekin ! verrazz0 Impianti radio, caricatori, ESC e batterie 8 22-02-13 08:31 PM
Motore Tekin RX8 elle72 Automodelli elettrici 1/8 Off Road 8 22-11-12 02:05 PM
Motori Tekin 1/10 cava Off Topic 2 22-10-12 10:52 AM
Tekin rx8 cbagl Automodelli elettrici 1/8 Off Road 30 22-06-12 01:12 PM
Controllo g10 Tekin remus123 Automodelli elettrici 0 23-12-06 08:57 PM
Tutti gli orari sono GMT +2. Attualmente sono le 03:40 PM.
