Vecchio 04-01-11, 02:49 AM   #1
Registrato dal: Dec 2009
residenza: SAN LUIS POTOSI, MEXICO
ALEX GAROLI è un newbie...
predefinito Tamiya yamaha yzr m1 laguna seca - rossi
Hi!, after building scratch bikes and modifying die cast bikes, I tought I deserved a good model kit, so I was thinking wich one to get, the Yamaha M1 Intercoloring edition with transkit, tje Model Factory Hiro Suzuki GSX Endurance version, or the Tamiya Honda RC166 with detail items, but my wife surprise me giving me the Tamiya Yamaha Intercoloring Edition, so here it is:
I loved the livery from this bike, here a image:
I want to make the superdetailed version, I have seen some incredible builds in forims like this:
Here is the Top Studio transkit:
And this is the Tamiya Fork for this model:
So I ordered a lot of "aftermarket" items for this bike, the first one was the Top Studio trasnkit:
To tell the true I expected a lot more, is called "superdetail kit", so I tought it included the chain, more photoedched parts, like front disks, mesh, clutch, I espected screws, but not, and the instructions are not so clear, I dont know where most of the cables and wires go:
And here are some items I ordered, the fork came from Ebay Hong Kong, other parts fron United States, some others fron Hiroboy and Strada Sports, and some from Australia:
Im still need to order the chain tensioner from Tiner Model Manufactory and some screws.
ALEX GAROLI non è in linea   Rispondi quotando
Vecchio 04-01-11, 03:03 AM   #2
So I began the build, I jump from one section of the bike to another so the primer or the glue dries, so it looks like a messy build.
Engine assembly:
Cutting the exhaust tail to add the metal one:
And need to sand the atachmet to hold it with the photoedched one and added one more divition:
Some putty on the front fender, and I erased the simulated screws to add real ones:
I began the selection of pieces wich are diferent black and the carbon fiber ones, te internal parts ofo some resin parts simulate carbom fiber texture, I love it:
And here is part of the carbon fiber application:
Testing the air valves:
Vecchio 04-01-11, 03:20 AM   #3
Some advance on the engine:
Cutting radiator mesh:
Some fork work:
I noticed in some other WIP two pieces that the Tamiya kit doesnt have:
Check out the really small allen screws:
More little screws:
Rear suspension work:
Look at the photoedched simulates crews on the rear shock mount:
Vecchio 04-01-11, 03:32 AM   #4
I made the frame and rear suspension interior with thick paper, and then covered with primer, and some parts with epoxy putty, then sanded with a dremel tool:
Eliminating foot pegs to add the Top Studi oones:
I still need to add some welds in the frame and rear arm.
I finished the rims:
Vecchio 04-01-11, 03:51 AM   #5
I painted some parts to began the mechanical assemblies:
Exhaust need the blue shades, springs hooks and springs.
I began the racing stand:
Testing parts:
Brake caliper details:
Vecchio 04-01-11, 04:16 AM   #6
Next thing to build is the handlebars:
This piece was really hard to get from the resin tree:
I had to make some scratch pieces:
I began some of the electronic pieces:
Vecchio 04-01-11, 04:22 AM   #7
I made the holes to receive the real screws in the fairings and some other detailslike the holes for the tv cameras cables:
Vecchio 04-01-11, 08:33 AM   #8
non riesco a caricare le foto..sono quasi tutte a metà..Dipende dal mio pc o è per l'alto numero di immagini?
Peccato,è un lavoro molto ineterssante da guardare....
Ultima modifica di sandro67; 04-01-11 a 08:38 AM
Vecchio 04-01-11, 10:00 AM   #9
L'avatar di zanna
Registrato dal: Nov 2003
residenza: Reggio Emilia
zanna inizia ad ingranare.
idem, secondo me troppe foto :-( è un gran bel lavoro!!!!!!!!!
Vecchio 04-01-11, 10:21 AM   #10
L'avatar di SPLASH
SPLASH inizia ad ingranare.
Ciao io le vedo tutte.... great job alex... amazing details.. Gooooo !!!!
SPLASH non è in linea   Rispondi quotando
Vecchio 04-01-11, 11:02 AM   #11
residenza: Bolzano
pure io le vedo tutte.. e non so se sia un bene.. fantastico!!!
Vecchio 23-01-11, 12:58 AM   #12
Hi, I got the Renaissance camera set,
I will put in the bike the under tail camera, the on the tail, but I dont know where the camera that takes the rider hand is located
also I dont know if the fron hole in the Yamaha's fairing is the camera hole:
I wonder if somebody could help me!!!
Vecchio 25-01-11, 11:10 AM   #13
ez9
L'avatar di ez9
Registrato dal: Feb 2007
ez9 è un newbie...
Hi alex, great job!
You got the point, the front camera it's exactly in the hole that you highlighted, but for the throttle camera, you cannot use on your bike!
If you are doing the #46 you should know that Valentino never had on his bikes a camera that point to the left hand because probably he want to keep secret the way how he mix the throttle and brake!
Just put the front camera and the back camera.
Ciao Alex bel lavoro!
La camera frontale e' esattamente nel foro che hai indicato tu, ma per la camera del gas, non puoi utilizzarla sulla tua moto!
Se stai facendo la #46 devi sapere che Valentino non ha mai avuto nelle sue moto una camera che punta alla mano sinistra perche' probabilmente vuole tenere segreto il modo in cui combina il gas e il freno.
Metti solo la camera frontale e quella posteriore.
ez9 non è in linea   Rispondi quotando
Vecchio 17-08-11, 12:20 AM   #14
Registrato dal: Jul 2011
residenza: Brindisi
Skiddolo è un newbie...
very great job no news?
Skiddolo non è in linea   Rispondi quotando
[News] Livree Yamaha Laguna seca zanna Statico - Kits, Info e Varie 15 24-07-10 11:44 AM
[moto]yamaha yzf-m1 2005 laguna seca bassaidai Statico Work in Progress 35 06-07-09 09:00 PM
[MOTO] Yamaha M1 2005 Laguna Seca freon Statico Work in Progress 38 25-10-08 09:24 AM
Tamiya 14104 Yamaha M1 Laguna Seca michele147 Statico - Kits, Info e Varie 42 21-07-08 04:51 PM
Foto Yamaha M1 Laguna Seca 2005 robi_j Statico - Kits, Info e Varie 2 02-06-06 10:30 AM
Tutti gli orari sono GMT +2. Attualmente sono le 06:47 PM.
