Vecchio 04-05-12, 09:05 PM   #1
L'avatar di verrazz0
residenza: imola
predefinito EB48 Electric 1/8th 4WD Buggy - Tekno RC [automodelli elettrici]
100% Tekno RC Designed and Tested in Southern California.
Chassis:
Designed to be electric from the ground up - no nitro conversions here!
4mm CNC 7075 aluminum hard anodized lightened chassis.
Super narrow chassis - widest point is only 125mm (less than 5”) mudguard-to-mudguard.
Class leading front and rear clearance (short chassis overhang) provides better bump handling and jump landing.
Integrated battery tray/mud guard, battery is sunken into chassis for a super low COG.
Integrated electronics tray/mud guard for easy removal of electronics.
Spacious, enclosed, easy access radio box with integrated transponder mount.
Single pack configuration is better balanced, lighter weight, and makes battery changes easier. Battery tray accommodate 2x2s packs.
Adjustable chassis brace system for fine tuning flex with front, center, and rear braces.
Differentials and Drivetrain:
3 fluid filled adjustable super lightweight diffs.
Less rotating mass = better acceleration.
Straight center driveline for maximum efficiency and minimal wear.
CV driveshafts with captured pins on all 4 wheels.
tante altri informazioni qui
tratto da Tekno RC - Brushless Kits, Motors, Conversions, Parts
Vecchio 04-05-12, 10:19 PM   #2
L'avatar di gabri500
Registrato dal: Nov 2010
sento puzza di hotbodies d8 hara
Off-Road Action Genova
...e ricorda: TRAXXAS M*RDA
Vecchio 04-05-12, 10:20 PM   #3
L'avatar di Omar94
Registrato dal: May 2009
residenza: empoli
Omar94 diventerà qualcuno prima o dopo!
Invia un messaggio tremite MSN a Omar94
sniff sniff..... già la sento anche io
auto : Crono Rs9
motori : Novarossi N21BC-5 \ ARROW GTR .21
ROCK ON!
Omar94 non è in linea   Rispondi quotando
Vecchio 05-05-12, 01:57 PM   #4
aggiungo il video del modello in azione...
Vecchio 05-05-12, 02:05 PM   #5
qui potete trovare info piu dettagliate e parecchie foto dei particolari della macchina...NeoBuggy.net - Tekno RC's EB-48 Electric Buggy - Headline News - News
Vecchio 05-05-12, 02:09 PM   #6
riflettevo un po meglio sulla macchina...non sembra male! il fatto che avantreno e retrotreno siano copiati dalla d8 hara no mi dispiace, visto che si tratta di una signora macchina...è interessante, anche se gia vista su hobao hyperstar-E, la soluzione del differenziale centrale molto spostato indietro, anche il baricentro sembra molto basso...voi che dite???
Vecchio 05-05-12, 03:29 PM   #7
L'avatar di franci98(2)
Registrato dal: Dec 2010
franci98(2) diventerà qualcuno prima o dopo!
Invia un messaggio tremite Skype a franci98(2)
non sembra fatta male, ma sinceramente a me non piacciono molto le macchina cosi tanto strette, voglio che la roba dentro respiri!
la corona del diff centrale in plastica. qualche sassolino e la ritrovi liscia?
il telaio e strettissimo, son piu pance che telaio ...
il portapile lo facevano 1mm piu verso l'interno e strusciava
in continuazione contro il cardano
diciamo che prima di poter dare un opinione...va vista e toccata con mani
Team Durango DEX408 (in vendita)
Sworkz S350 Be1 - LRP IX8 - LRP Dynamic 2200kv
Ultima modifica di franci98(2); 05-05-12 a 03:33 PM
franci98(2) non è in linea   Rispondi quotando
Vecchio 05-05-12, 03:47 PM   #8
Originariamente inviata da franci98(2) Visualizza il messaggio
già...anche le losi a dir la veritò ce l'hanno di plastica...io il truggy l'ho maltrattato parecchio, usandolo nei campi, ghiaia, boschi...ma non si è rovinata
Vecchio 05-05-12, 03:51 PM   #9
dipende dalla qualita della plastica se qualcuno la prende potremo verificare anche quello
Vecchio 05-05-12, 05:44 PM   #10
L'avatar di GTi16
Registrato dal: Jan 2010
GTi16 diventerà qualcuno prima o dopo!
Edito:
La tekno ha sempre fatto conversioni sullo stile hyper 9e, in questa però qualcosa cambia.
Infatti con diff centrale non direttamente collegato alla cassa (come sulla hobao)con l'aggiunta del puntalino penso che sia stato risolto il solito problema di flessione che si ripercuote sul cardano causata appunto dall'assenza di puntalino post.
La corona in plastica non da problemi e il portalipo è 1 mm meno quindi che ti lamenti
Ultima modifica di GTi16; 05-05-12 a 05:48 PM
GTi16 non è in linea   Rispondi quotando
Vecchio 05-05-12, 07:12 PM   #11
Originariamente inviata da GTi16 Visualizza il messaggio
che starei fisso a gurdare che non sfreghi mi da piu sicurezza sapere che ha piu spazio e se cifosse la remota possibilità di un portapile fallato con il portapile che rientra di 1mm in piu? mi consumo la plastica
beh preferisco averla in metallo su questa scala se non sbaglio la chisco 7.5 ce l'ha in plastica e sentivo che dava problemi
Vecchio 05-05-12, 07:17 PM   #12
residenza: imola
La kyosho VE , la Losi 8ight EU , la Durango DEX 408 e probabilmente le hanno anche altre , di serie sono di plastica e io di tutte e 3 ho visto le corone senza qualche dente
Vecchio 05-05-12, 07:17 PM   #13
Lo scoppio é diverso franci...li il metallo é d'obbligo!
Vecchio 05-05-12, 07:20 PM   #14
Originariamente inviata da verrazz0 Visualizza il messaggio
sei dalla mia parte?
@gabri: piu che diverso, mi sa che sono piu scelte progettuali e per questione o di costi o qualita che è buona... senno perche la 808e, per esempio, la corona non la monta in plastica?
Ultima modifica di franci98(2); 05-05-12 a 07:22 PM
Vecchio 05-05-12, 07:24 PM   #15
L'avatar di GTi16
Dipende dal tipo di plastiche ragazzi, dai non mettete a confronto giocattoli con modelli seri
Comunque per questa macchina sono 420 pippi eh, siamo in linea con le altre più o meno
Ultima modifica di GTi16; 05-05-12 a 07:31 PM
mini-Z buggy kit version - kyosho [automodelli elettrici] gabri500 News dal mondo del modellismo 8 16-02-14 09:52 PM
1:10 EP SANDMASTER BUGGY - Kyosho [automodelli elettrici] gabri500 News dal mondo del modellismo 8 17-04-12 03:08 PM
Coyote desert buggy - HPI [automodelli elettrici] gabri500 News dal mondo del modellismo 3 15-03-12 10:04 PM
Hornet Jun Watanabe Edition Buggy 1/10 - Tamiya [ automodelli elettrici ] verrazz0 News dal mondo del modellismo 4 17-02-12 05:11 PM
Motori e regolatori automodelli - Hacker [ Automodelli elettrici ] verrazz0 News dal mondo del modellismo 3 10-02-12 06:43 PM
Tutti gli orari sono GMT +2. Attualmente sono le 03:07 PM.
