Vecchio 11-03-09, 07:40 PM   #1
L'avatar di tamburino
Registrato dal: Sep 2008
tamburino diventerà qualcuno prima o dopo!tamburino diventerà qualcuno prima o dopo!
predefinito mbx6r????????
raga!!!
non riesco a capire se il modello che presentano
è una 6 normale o è uscita la 6r!!!!
certo che dopo 6 mesi
qualcuno sà qualcosa
<DIV id=container> Search View Cart0 items
My Account Wish list Support
MBX6R Buggy Kit by Mugen Seiki USA
Email a Friend
$609.99
List: $949.99
Usually ships in 2-3 Business Days
MUGE0050 by Mugen Seiki USA
More in this Category
More in this Brand
MBX6R Buggy Kit
Key Features
  • 3 Differential Shaft Drive 4WD
  • Low Center of Gravity Fuel Tank
  • A70-75 (T6) Alum 3mm Chassis
  • 15mm Threaded Front/Rear Shock Sets
  • 4mm Front/Rear Carbon Graphite Shock Towers
  • New Geometry Front Suspension
  • Center/Front/Rear Universal Drive Shafts
  • Self-Locking Wheel Nuts
  • Rear Suspension Mud/Dirt Guards
Overview
Mugen Seiki Racing is proud to introduce the New MBX6 1/8 Off-road Buggy (MUGE0050). This buggy is all new from the chassis up!
The MBX6 has all-new design front and rear suspension components, including front and rear bulkheads. All the drive train is light weight to reduce rotating mass, aluminum front pillar balls, and the list goes on.
The lay out for the engine, fuel tank and radio gear have been moved as close a possible to the center of the chassis to make the MBX6 as nimble as possible.
Mugen Seiki Racing used its World Championship knowledge to continue to be the leader in the 1/8 off-road buggy market.
Specs
  • Type:Gas Off-road Buggy Kit
  • Scale:1/8th
  • Width:309 mm
  • Wheelbase:315-320 mm
  • Chassis:Aluminum A70-75 (T6) 3 mm
  • Drive Train:3 Differential Shaft Drive 4WD
  • Motor or Engine:.21 Offroad (see MUGJX21B01)
Parts & Accessories
MBX6R Buggy Kit
by Mugen Seiki USA</SPAN>
$ 609.99</SPAN>
mugen, mbx6r buggy kit, mbx6, mbx6r, go to product page
109 visitors also liked this.
<DIV id=footer>Store Locator
Find a Hobby Shop Near You
international dealer locator
Don't Be the Last to Know
Sign up now for our free publications and emails.
<DIV id=waysToShop>3 Ways to Shop
Find a Retailer Near You
US | International
By Phone: <FONT color=#333333><FONT face=Tahoma>
tamburino non è in linea   Rispondi quotando
Vecchio 11-03-09, 08:26 PM   #2
ENEA
Penso, anzi sono sicuro, sarà il mio prossimo buggy
Vecchio 11-03-09, 08:36 PM   #3
L'avatar di crono_rs7gr
crono_rs7gr è un newbie...
facile ke sia uscita la R... perche quelli ke conosco io ke ce l'hanno nessuno ne ha parlato bene fino adesso... dicono sia troppo nervosa
crono_rs7gr non è in linea   Rispondi quotando
Vecchio 11-03-09, 08:49 PM   #4
L'avatar di babyfurious2
Registrato dal: Jan 2006
residenza: Carpi, Modena
sono sicuro al 99,9% sia solo una dicitura di horizon, mbx6r non ne sono uscite ufficialmente da mamma mugen, o al massimo può essere un pacchetto particolare di horizon (anche se dubito) con inclusi alcuni optional, o al massimo la dicitura per identificare gia le nuove mbx6, caratterizzate da lievi modifiche ai bracci ant, scatola ricevente, bicchierini ecc ecc.
Vecchio 11-03-09, 08:55 PM   #5
ENEA
Originariamente inviata da babyfurious2 Visualizza il messaggio
Quoto perfettamente
Vecchio 11-03-09, 08:57 PM   #6
L'avatar di amon
amon diventerà qualcuno prima o dopo!
è la 6 normale. hanno fatto degli aggiornamenti ma hanno cambiato la roba nelle scatole, non so niente riguardo a nuove versioni.
tra un po uscira la full optionals.. la prospec credo.
amon non è in linea   Rispondi quotando
Tutti gli orari sono GMT +2. Attualmente sono le 04:03 AM.
