Vai indietro   Forum Modellismo.net > Categoria Automodelli Elettrici > Automodelli elettrici > Automodelli elettrici 1/10 Touring
Vecchio 20-07-11, 05:48 PM   #151
L'avatar di cava
residenza: Como
A dm devi telefonare la sera. Il 4.5 non so se te lo tiene. Il 9 mi pare sia 4500kv o 4900
Vecchio 20-07-11, 06:47 PM   #152
L'avatar di blot11
blot11 inizia ad ingranare.
Cosa?
Comuqnue tiene fino a 5.5, ho sbagliato link infatti Era questo Platinium Brushless Motor 5.5T - MOTORI brushless - MOTORI - ELETTRONICA
1 Specification
1.1 Output: Continuous current 60A, burst current 380A.
1.2 Input: 4-9 cells NiMh/NiCd or 2-3 cells LiPo. Note1
1.3 BEC Output: 6V/1.5A.
1.4 Resistance: 0.00075 Ohm.
1.5 Motor Supported: Sensorless Brushless Motor
1.6 Suitable Brushless Motor: 5.5T and > 5.5T
1.7 Suitable Car: 1/10 on-road or off-road cars / trucks for normal race or sportful race.
1.8 Size: 31.5mm(L) * 27.5mm(W) * 24mm(H).
1.9 Weight: 32g(Without wires)
Note1:
For 4-6 Cell Ni-xx: You needn’t change the fan coming with the ESC;
For 7-9 Cell Ni-xx: You must change the fan because it cannot work with such a high voltage, so please choose a high voltage fan or supply the fan from the receiver (+6V);
2 Features
2.1 Compatible with all sonsorless brushless motor.
2.2 Use top quality electronic components to enhance the current endurance ability of the ESC.
2.3 Excellent start-up, acceleration and linearity features.
2.4 With 2 running modes (Racing mode and Forward/Backward mode).
2.5 With 4 steps of maximum reverse force adjustment.
2.6 Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
2.7 With 4 start modes (Also called "Punch" ) from "Soft" to "Very aggressive".
2.8 Multiple protection features: Low voltage cut-off protection for lithium or nickel battery / Over-heat protection / Throttle signal loss protection / Motor blocked protection.
2.9 With 8 steps of timing adjustment to get the best compatibility with various of motors.
2.10 Easily program with only one button and compatible with pocket-sized program card.
blot11 non è in linea   Rispondi quotando
Vecchio 20-07-11, 08:08 PM   #153
L'avatar di franci98(2)
Registrato dal: Dec 2010
franci98(2) diventerà qualcuno prima o dopo!
Invia un messaggio tremite Skype a franci98(2)
io non andrei fino al limite, mi terrei su un 6.5 per sicurezza, poi fai te
Team Durango DEX408 (in vendita)
Sworkz S350 Be1 - LRP IX8 - LRP Dynamic 2200kv
franci98(2) non è in linea   Rispondi quotando
Vecchio 20-07-11, 08:14 PM   #154
L'avatar di blot11
Originariamente inviata da franci98(2) Visualizza il messaggio
E quale mi consigli?
Vecchio 20-07-11, 08:22 PM   #155
NOS90671 Storm Evolution modified motor 6.5 turns - MOTORI brushless - MOTORI - ELETTRONICA
Vecchio 20-07-11, 10:43 PM   #156
L'avatar di blot11
Lo regge bene dite?
Vecchio 20-07-11, 11:06 PM   #157
lo regge, lo regge, ma ci sono motori che dei kv in piu e rischi, per questo ti ho detto di tenerti una spira sopra
Vecchio 21-07-11, 11:15 AM   #158
L'avatar di blot11
A ok ma per programmare l'esc quale programm card devo prendere?
Vecchio 21-07-11, 04:24 PM   #159
L'avatar di saettamcqueen
Originariamente inviata da blot11 Visualizza il messaggio
Se prendi l'ESC 60A che hai postato, ti serve quella della HW.
saettamcqueen non è in linea   Rispondi quotando
Vecchio 21-07-11, 06:56 PM   #160
L'avatar di blot11
Originariamente inviata da saettamcqueen Visualizza il messaggio
E quele è? L'esc l regge quel motore no?
Vecchio 21-07-11, 09:36 PM   #161
Digita "program card Hobbywing" e viene fuori, ce ne sono di due tipi, a seconda se l'ESC è della serie V1 o V2.
Quel motore ha 6900kv, io su quell'ESC al max ci monto un 6000kv, non saprei dirti.
Vecchio 21-07-11, 09:42 PM   #162
L'avatar di blot11
E allora quale altro motore mi puoi consigliare tenendo conto che giro su una pista da scoppio?
Vecchio 21-07-11, 09:56 PM   #163
Ma l'ESC lo hai già comprato?
Altrimenti fai prima a prendere un ESC che regga motori con minor numero di spire (anche per il futuro), così sei sicuro che il motore da te scelto ci va senza problemi
Vecchio 21-07-11, 10:10 PM   #164
L'avatar di blot11
No ma esc + motore deve stare sulle 110-120 massimo... Ti ho dato una rep
Sei passato a verde
Vecchio 21-07-11, 10:27 PM   #165
Sei passato a verde
Potresti prendere un 120A come ESC e poi quel motore: sei intorno ai 130/140 totali.
Altrimenti puoi prendere un ESC usato (tanta gente li cambia di continuo per avere l'ultima novità) e stai tranquillamente dentro il tuo budget. Chiaro che devi avere un pò occhio all'acquisto.
Consiglio nuova rc 1/10 elettrica Lipox Automodelli elettrici 1/10 Touring 18 14-03-11 08:33 PM
Acquisto auto elettrica? Giacos Automodelli elettrici 104 06-04-10 05:21 PM
Nuova Moto Thunder Tiger Elettrica gnagnolone1964 Thunder Tiger 5 07-09-09 11:02 AM
convertire nuova faor scoppio in elettrica falcon1 Moto radiocomandate 7 06-11-05 10:34 PM
Vendo moto elettrica THUNDER TIGER NuOvA!!! theredcat Moto radiocomandate 6 06-11-05 09:53 AM
Tutti gli orari sono GMT +2. Attualmente sono le 03:25 AM.
