Mini PRO....ecco le supercar..!!
Usciranno il 17 Dicembre 2 nuove mini PRO
..la novita' e' che avranno la carrozzeria in Lexan !! ecco una gustosa Anteprima. Item No: 18609 - TORCRUISER trickles - the - Total length = 154mm 1/32 mini- four running PRO series No.9 - the style which makes the sport car of TORCRUISER & the actual car think mini- four running PRO of charm is appearance. * Adopting the same straw raincoat polycarbonate make clear body with RC. * As for chassis of high efficiency double shaft motor midship type good balance. * In the mount part bis as for the body which stops being one-touch, removal and re-installation possibility. * In small diameter tire 3.5: Setting the super fast gear of 1. |
Re:Mini PRO....ecco le supercar..!!
ed ecco la seconda..
Item No: 18610 - VELDAGA ベルダーガ Total length = 154mm1/32 mini- four running PRO series No.10 - VELDAGA * being lightweight, adopting the polycarbonate make clear body which is strong in the shock. The low/row & wide the aero dynamic forum emphasizes the speed impression. * As for chassis double shaft motor midship mount. * To install the small diameter tire which is the scale impression, 3.5: Setting the super fast gear of 1. * You can use also the upgrade part which is even abundantly. |
questa era L'anteprima...
ora vediamo i...Dettagli !!!! As for these 2 units of December 17th sale, machine of sport car type. Because it has become the lightweight clear body, everyone favorite the color ring is made to enjoy. Already, with the new product guide and the leaflet etc., as for package illustration you think that the one which you view it is but when you try looking at the コレ real thing, you say or in addition that the 3-D arises, (natural! ? ) Don't you think?, in illustration and the real thing image is different in good sense. Then! Today you try you probably to view the color variation. As for designated color of standard the trickle - the - lead-lead and ベルダーガ it is the silver, but if body color changes, also impression may change respectively, is, don't you think?? With the ゆ - it tried painting right away with reason! |
Queste carrozze in lexan si prestano bene per colorazioni da vere fuoriserie...
ancora qualche immagine...
la TORCRUISER |
e la VELDAGA....
ecco l'interno della carrozzeria...
ma le novita' non son finite....
ecco altre 2 carrozze in lexan..
loro sigla : MS-05 ..MS-06.. |
..MS-06
..ancora una versione della VELDAGA.....si nota a dx..una carrozza semi dipinta..
Naturalmente la presentazione e' avvenuta durante il 2° "event"...PRO
con immancabile gara su Pista a 5 corsie...
...sui motori, dopo il Rev ecco il Torque...non e' quello che ci si aspetta..salvo che non abbiano cambiato le caratteristiche...
ci vorrebbe un motore da 24-26000 rpm..con 15-16 gr/cm |
WOW, molto belle.
Si possono usare su gli altri telai? |
Tutti gli orari sono GMT +2. Attualmente sono le 02:51 PM. |
