Vecchio 28-10-17, 12:29 AM   #1
Registrato dal: Mar 2015
residenza: Favara (AG)
extrabrushless ha avuto comportamenti non adeguati in passato...
predefinito Ricaricare BOSCAM RX LCD5802
Buonasera.
Ho acquistato da poco un monitor per FPV, ovvero il boscam rx lcd5802.
Non so però come devo ricaricarlo. Ho letto il manuale e dice che la batteria interna è una 7.4V Li-POLYMER, ma come ingresso trovo stampato 12V.
Adesso mi chiedo, come posso caricarlo correttamente? Se lo volessi caricare con il caricabatterie, devo impostare Lipo o cos'altro? A quanti Volt lo devo mettere?
Grazie a chi mi saprà aiutare. Scivo qui per evitare errori e di conseguenza bruciarlo
Incollo le specifiche e allego il manuale in pdf.
Specification:
2 Built-in 5.8Ghz Dual diversity receiver automatically for best reception
2 Built-in 2CH 5.8Ghz AV output and 1CH AV input
2 Built-in high performance Li-POLYMER Battery: 2450mAH/7.4V
2 Work status OSD display : RSSI indication ; Battery indicator;Channel indication
2 A key to automatic signal search
2 Support Chinese and English menu
2 Size: 180mm x 120mm x 50mm(Note:Sunshield height:28mm)
2 Working Voltage: DC 7~16V
2 Power Consumption: 650 mA @12V
2 Battery charging current : 850mA @12V ( max )
2 Working temperature: -10°C~+ 65 °C
Features:
2 Built-in Dual Receiver Automatically for best reception Automatic Antenna Switching
2 Dual buffered AV outputs
2 Can receive 2 different channels at the same time
2 Not affect by 2.4GHz R/C Radios
2 AV Receiver with Diversity inputs
2 Small, light weight, durable
2 4 Bands and total 32 Channels
2 Built-in battery , easy to carry and outdoor use
2 A key to automatic signal search,Simple operation
2 Work status OSD display:Always be aware of the device working condition.
JACK:
4)DC/+12V: DC IN, +12 V power supply , the device operating current of 650 mA @ 12V,
built-in battery maximum charge current of 800 mA @ 12V; if the device is
working when charging , please pay attention to selecting the rated current
greater than 2A/12V charging equipment;
File allegati
Tipo di file: pdf SDLCD32_datasheet.pdf (56.5 KB, 401 visite)
Auto: Losi 3.0E.
Aereo: kyosho calmato sport 60 8.5cc, jamara trainer 46 7.5cc, jamara dragonfly 15cc, cessna famous 182, yak 54
Radio: Taranis X9D Plus
extrabrushless non è in linea   Rispondi quotando
[Video] Boscam Galaxy D4 FPV LCD RX & DVR Monitor - Recensione - Parte 2 Issam News dal mondo del modellismo 0 27-01-16 12:29 PM
[Video] Boscam Galaxy D4 FPV LCD RX & DVR Monitor - Recensione - Parte 1 Issam News dal mondo del modellismo 0 21-01-16 10:29 AM
Problema con Boscam FPV 5.8G 400mW AV Ricevitore RC805 con trasmettitore TS353 flypassion Impianti radio, caricatori, ESC e batterie 0 31-05-15 08:42 AM
Come ricaricare gli ammortizzatori devys Automodelli elettrici: recensioni, trucchi e guide 18 05-03-13 10:08 AM
ricaricare bene. federx Automodelli elettrici 2 27-01-07 11:36 PM
Tutti gli orari sono GMT +2. Attualmente sono le 08:13 PM.
