-   Automodelli elettrici (https://www.modellismo.net/forum/automodelli-elettrici/)
-   -   ASSOCIATED RC8T -electric truggy - (https://www.modellismo.net/forum/automodelli-elettrici/67338-associated-rc8t-electric-truggy.html)
ENEA 04-03-09 11:29 AM
Anche Associated ha messo fuori il suo "mostro".
“Team Associated is proud to release the RC8Te, a 1:8 scale electric- powered competition truggy kit based on the championship-winning RC8T platform! The RC8Te engineering team has developed a practical design that incorporates the same exceptional strength, durability, cornering capability, jumping ability, and rough track handling that characterize the nitro-powered RC8T. With special features such as a hard-anodized machined chassis, correctly balanced and optimized weight distribution, composite Big Bore shocks featuring 4mm gold shafts, upgraded steering system, and lightweight wheels, every inch of the RC8Te screams high-performance and durability. Enjoying the awesome performance, convenience, and cleanliness of electric power has never been easier!
RC8Te Kit Features:
• Molded battery tray supports two ROAR-approved 1:10 scale size 7.4v LiPo
battery packs with room for foam pads
• Receiver box, servo, and battery tray remove from car in one piece for easy
maintenance and cleaning
• Convenient wire routing keeps critical electronic wires out of drive-train
components and simplifies disassembly
• Includes pinion gear (16T) and molded composite spur gear (50T)
• Rigid one-piece motor mount utilizes standard motor screw mounting pattern
• Large elevated speed control mounting area allows for easy screw mounting
of common speed controllers
• Upgraded dual bell-crank steering for more consistent steering and reduced
bump-steer
• 16mm Big-Bore molded composite shocks with pre-load clips
• Hard anodized 7075-T6 aluminum chassis
• 3mm aluminum shock towers
• Durable 12mm thick suspension arms
• Rear molded CVA boots to keep dirt and mud out of rear joints
• Alloy steel turnbuckles
ELECTRONIC COMPONENTS NOT INCLUDED
See next page for more features!
• Caster blocks adjust 14, 16, or 18 degrees with molded inserts
• Adjustable suspension pivot bushings for different pivot height options
• 4.30:1 ratio gearboxes
• 3.5mm light CVA drivetrain
• Pre-drilled wing with adjustable angle and location
• Blue aluminum drive hexes
• Blue aluminum nylock wheel nuts
• AE LPR lightweight truggy wheels (#89360)
• Utilizes 3 hook-and-loop straps to secure LiPo batteries into battery tray
• Enclosed receiver box to protects electronic components
• 1.5mm thickness unpainted polycarbonate RC8T body”
TONYM73 04-03-09 01:21 PM
Veramente un bell'oggettino,recensito in anteprima nel mio blog:tunz6rh:: http://www.modellismo.net/forum/blog...elettrico.html
ENEA 04-03-09 07:58 PM
Io ho iniziato con l'elettrico, poi perς sono passato al nitro, comunque mi diverto con tutti e due, e sinceramente se esce qualche "bestiolina" 1/8 elettrica, la compro di sicuro. Anche se per l'automodellismo elettrico siamo in una fase di transazione, cioθ tra poco tutte le ditte sforneranno modelli sempre piω agguerriti e potenti.
Tutti gli orari sono GMT +2. Attualmente sono le 11:03 AM.
