poi c'è la versione upgrade
1/16 Brushless 4WD Mini Rally - Extreme Edition
Ecco un video, dall'imballaggio alla prova su piazzale e su terreno:
https://www.youtube.com/watch?v=08PpQCuU07g
E un video promozionale
https://www.youtube.com/watch?v=fuzVE_EW_CM
The Turnigy 1/16th Mini Rally Extreme is packed with features. Fully adjustable suspension such as front toe in and out, adjustable shock absorber locations and preloading, adjustable chamber settings, adjustable drop height, sway bars as standard and the list goes on! The Mini Rally Extreme has all the tunability of a car twice is size and double its price allowing you to truly customize the feel and performance of your ride.
The full time 4WD transmission is delivered blistering power from the 2040-4800kv Brushless motor and 25Amp Esc combination fitted as standard, no old school brushed junk to have to "upgrade" from here!
Aggressive styling, hot out of the box performance and real tunability are set to make this one of the hottest 1/16th cars to hit the streets in 2012!
Features:
Oil filled adjustable Shock absorbers
Anti roll sway bars as standard
Fully ball raced
Light weight glass fibre chassis
Tunable suspension geometry
Strong 15g Steering servo
Brushless power train as standard
Spare Parts Available
Aluminium upgrades coming soon!
Spec.
Motor:
Brushless Inrunner 2040-4800kv
ESC:
25A Brushless 2~3S (with Reverse)
Battery:
2S LiPo (103x33x27mm MAX SIZE) w/ XT-60 connector (Required)
Servo:
15g Micro
Drive Train:
Full Time 4WD, Twin Diff with Center Shaft Slipper Clutch
Suspension:
Adjustable Oil Filled
Length:
325mm
Width:
180mm
Height:
122mm (With Body Shell)
Required.
2S 1700mAh LiPo (or larger)
Radio System (Rx/Tx)
Questa alla fine costerà 100-105€.
