Vecchio 10-01-20, 01:52 PM   #46
Super Moderatore
L'avatar di gnanni
Registrato dal: Apr 2001
- Figura motociclista stradale 1:12 Tamiya http://bit.ly/2SWCFCy
- Toyota GR Supra 1:24 Tamiya http://bit.ly/39Mx3Rk
- Lockheed P-38 F/G Lightning 1:48 Tamiya http://bit.ly/36wltaN
- Dima per misure Mini4WD Verde Tamiya Mini4wd http://bit.ly/2tz897c
- Rotelle alluminio 19 mm anello Viola Mini4wd Tamiya http://bit.ly/2FseMdZ
- Gomme largo diametro Slick Maroon Tamiya Mini4wd http://bit.ly/300HWKY
- Stabilizzatori anteriori a cilindro Clear Viola Tamiya Mini4wd http://bit.ly/2FF9wEd
- Cerchi alluminio largo diametro stretti II Tamiya Mini4wd http://bit.ly/36A4nZU
- Side Cutter AK Interactive http://bit.ly/35ueFcE
- Plier Cutting Tool AK Interactive http://bit.ly/36ykYgC
- Precise Straight Tweezers AK Interactive http://bit.ly/35q402A
- Precise Curved Tweezers AK Interactive http://bit.ly/2Fv49ai
- FX-4 London Black Cab 1968 1:24 Aoshima http://bit.ly/36vgabS
- Mercedes-Benz G230 1:24 Italeri http://bit.ly/2FvBSka
- Lockheed Martin F-35 B Lightning II STOVL version 1:72 Italeri http://bit.ly/35voxTr
- Mikoyan Gurevich MiG-23 MF/BN Flogger 1:48 Italeri http://bit.ly/2Qxli9W
- Stalingrad Siege 1942 - Battle Set 1:72 Italeri http://bit.ly/2Qzk6CW
gnanni non  in linea   Rispondi quotando
Vecchio 17-01-20, 12:07 PM   #47
Super Moderatore
L'avatar di gnanni
- Diluente per acrilici Tamiya http://bit.ly/3aepkM8
- Rivet Maker Revell http://bit.ly/36XQlkH
- Paint Doser Bottles 30ml AK Interactive http://bit.ly/2RhtwlG
- Paint Doser Bottles 3x 100ml AK Interactive http://bit.ly/387eBB3
- Double Sided Sponge AK Interactive http://bit.ly/2TmCW1T
- Six Wells Tray AK Interactive http://bit.ly/2RhwW80
- Supporto modello 1:10 in alluminio anodizzato nero Yeah Racing http://bit.ly/389r9ba
- LCD Program Card Hobbywing http://bit.ly/2RiYRnN
- Mini Manual Hand Drill + 7 Drill Bits HSS Artesania Latina http://bit.ly/2E9GA6X
- Sacchetto sassolini grana media 250 gr HO-TT-N-Z Noch http://bit.ly/2RnKUFa
- Sacchetto prato estivo 20 gr Noch http://bit.ly/2Nu4Epu
- Accessori per modellismo navale Amati http://bit.ly/2ToWQcw
Vecchio 24-01-20, 01:25 PM   #48
Super Moderatore
L'avatar di gnanni
- American Cars DeAgostini https://track.adform.net/C/?bn=33924152
- Auto da Rally Top Gear telecomandata Lego http://bit.ly/30K8wbw
- DeLorean Back to the Future Part I 1:24 Aoshima http://bit.ly/2Gjx3L7
- Giunca pirata Cinese - 1:100 Amati http://bit.ly/2sQVuMR
- Pinzetta con lente e luce a Led Modelcraft http://bit.ly/2Rk59ES
- Xtreme Metal Smoke Metallic AK Interactive http://bit.ly/3aFYA7A
- F1 SF90 Team Scuderia Ferrari 2019 1/43 Burago http://bit.ly/36dVKDe
- Davide Ongaro a Model Expo Italy https://youtu.be/zON9A-Hs2Jg
Vecchio 31-01-20, 01:14 PM   #49
Super Moderatore
L'avatar di gnanni
- MV Agusta 500 cc 4 Cylinders 1964 1:9 Italeri http://bit.ly/2RE0DBr
- Speed Star Dunlop Lola T90-50 1:24 Hasegawa http://bit.ly/2JQVrGF
- Suntory West Lola T90-50 1990 F3000 1:24 Hasegawa http://bit.ly/37yprAi
- Cabin Reynard 89D 1:24 Hasegawa http://bit.ly/2t3Xam6
- French Cuirassier Napoleonic Wars 1:16 MiniArt http://bit.ly/311toLx
- Railway Non-Brake Flatbed 16,5 t 1:35 Miniart http://bit.ly/2GuHwmW
- MULTIflight Plus Set Smart SX 6 Mode 2/4 Multiplex http://bit.ly/2RDDA9G
- Estrattore pignone per Mini4WD Tamiya http://bit.ly/316vCJj
- Cassetta portamotori Mini4WD universale Tamiya http://bit.ly/2RAcwIE
- Colla per modellismo Contacta Gel Revell http://bit.ly/38ZLctl
- Mini tappeto erboso 45x30cm Noch http://bit.ly/313Zl5K
Vecchio 07-02-20, 12:34 PM   #50
Super Moderatore
L'avatar di gnanni
- American Cars DeAgostini http://bit.ly/2ulkj4e
- Porta Aerografi Amati http://bit.ly/39ekaOV
- Clear Epoxy Resin Tamiya http://bit.ly/39aPXjH
- Hull support Artesania Latina http://bit.ly/2QrwYg2
- Soviet Tank Crew 1970-1980s Winter Uniform 1:35 MiniArt http://bit.ly/31pDl5E
- Modern Street Cafe 1:35 MiniArt http://bit.ly/31tXaJ1
- Mitsubishi Lancer Evolution IV 1997 Safari Rally 1:24 Hasegawa http://bit.ly/31swtUT
- SU-35S Flanker 1:72 Hasegawa http://bit.ly/2RXWPv0
Vecchio 14-02-20, 01:46 PM   #51
Super Moderatore
L'avatar di gnanni
- Taglia polistirolo elettrico 3 in 1 Modelcraft http://bit.ly/2SfGxxD
- Pinzetta HG Grip Type Tip Tamiya http://bit.ly/31KIrcD
- Set spessori in plastica Viola Mini4wd Tamiya http://bit.ly/37osoCQ
- Set freno AR Giallo fluorescente Mini4wd Tamiya http://bit.ly/2ShH9Tp
- Cerchi con razze a filo Low Profile Silver Mini4wd Tamiya http://bit.ly/37h3AN0
- Doppie rotelle alleggerite 13-12 mm Viola Mini4wd Tamiya http://bit.ly/2vl3Yga
- Rotelle coniche 19 mm senza anello Viola Mini4wd Tamiya http://bit.ly/31ITtPC
- Endeavour legno con attrezzi 1:80 Amati http://bit.ly/2tPwwhp
- Vernici sintetiche Humbrol http://bit.ly/31M1TWC
Vecchio 28-02-20, 01:25 PM   #52
Super Moderatore
L'avatar di gnanni
- Toolkit M6 Charger Caricabatterie Multiuso White Radiosistemi http://bit.ly/2PjeA6j
- ST8 Advanced Servo Tester Radiosistemi http://bit.ly/2viUtOC
- WM150 Advanced Watt Meter Radiosistemi http://bit.ly/2vi8Qml
- Cannone con affusto in legno 50 mm Amati http://bit.ly/2Th2eN4
- Natural Leaves Plants Neutral Protection AK Interactive http://bit.ly/2VldFpH
- MSTA-S Soviet/Russian Self-Propelled 152 mm Artillery Gun 1:35 Zvezda http://bit.ly/2VpPaYr
- Vought A-7E Corsair II 1:48 Italeri http://bit.ly/2Voo7N8
- Grumman F-14A Tomcat 1:72 Italeri http://bit.ly/2vfakhh
- Range Rover Classic 1:24 Italeri http://bit.ly/3a4Ukx7
- Scania Streamline 143H 6x2 1:24 Italeri http://bit.ly/2Vo0lB8
- Self Propelled Howitzer M110 1:35 Italeri http://bit.ly/3a21eDk
Vecchio 06-03-20, 01:38 PM   #53
Super Moderatore
L'avatar di gnanni
- Mini4WD Neo-VQS VZ Chassis Tamiya http://bit.ly/2uvmIcA
- Supporto anteriore rotelle FRP VZ Chassis Tamiya http://bit.ly/2TkkLJI
- Piastra posteriore rinforzata Super X Tamiya http://bit.ly/32TvVsa
- Acchiappa Mini4WD Red Version Tamiya http://bit.ly/2TopzgY
- Kit punte HSS da 0,3 a 1,6 mm (20 pz) PgMini http://bit.ly/2DYsepI
- Filtro anti condensa per Aerografo Belkits http://bit.ly/2Iius4X
- Survival Weathering Brush Set AK Interactive http://bit.ly/32O9Ue8
- Dassault Rafale C 1:48 Revell http://bit.ly/38jhzlX
- Lancia Delta S4 Rally 1986 Monte Carlo Rally 1:24 Beemax http://bit.ly/2IANdBi
- Fast & Furious diecast Jada http://bit.ly/39j5P45
Vecchio 10-03-20, 03:43 PM   #54
Super Moderatore
L'avatar di gnanni
Sconto dal 50 al 70% su oltre 4000 articoli di modellismo https://ebay.to/2Q39RWK
Vecchio 27-05-20, 05:19 PM   #55
Super Moderatore
L'avatar di gnanni
- Outback Mini Patriot Trail Ready 4WD 1:18 RTR FTX https://bit.ly/3bNyHSF
- Toyota Gazoo Hybrid TS050 2019 1:24 Tamiya https://bit.ly/3fsKHM4
- Porsche 935 Baby 1:24 Italeri https://bit.ly/3daj7ly
- Mini RC Claas Axion 960 Traktor RTR Revell https://bit.ly/2X3xG4I
- Set 4 mini ganci con impugnatura Modelcraft https://bit.ly/2X0OfhE
- Masking Tape Set of 4 (1, 2, 3, 6 mm) Modelcraft https://bit.ly/2AbMMMg
- Servo Tester Multi-mode Electronic Dreams https://bit.ly/2ZCDeVl
- Dima per circonferenza passaruota e taglio carrozzeria basso 1:10 Touring 65mm e M-Chassis 56mm Yeah Racing https://bit.ly/2X7aItz
- Connettori tipo Deans con protezione Maschio/Femmina Yeah Racing https://bit.ly/2Mcm0Xb
- Supporto modello alto in alluminio anodizzato Blu Electronic Dreams https://bit.ly/2LYbB0O
- Concorde British Airways 1:144 Revell https://bit.ly/2M5sirb
- Renault 5 Turbo telaio M-05Ra 2WD 1:12 Kit Tamiya https://bit.ly/2M27aSV
Vecchio 05-06-20, 02:59 PM   #56
Super Moderatore
L'avatar di gnanni
- Super Clod Buster Black Edition 4WD 1:10 Kit Tamiya https://bit.ly/2XkMHxJ
- Alfa Romeo Giulia Sprint GTA telaio M-05Ra 2WD 1:12 Kit Tamiya https://bit.ly/3dBndDu
- Suzuki GSX1100S Katana Custom Tuned 1:12 Tamiya https://bit.ly/2Ax5o9Q
- Kawasaki Ninja H2 Carbon 1:12 Tamiya https://bit.ly/2XtRZZ9
- U.S. M8 Light Armored Car Greyhound Set 1:35 Tamiya https://bit.ly/2yYGuzq
- Carrier Deck Section 1:72 Italeri https://bit.ly/3ctHkCa
- Cordless Foam Cutter Modelcraft https://bit.ly/3dwwP22
- Contenitore protezione ricarica LiPo Large (23x30 cm) https://bit.ly/3cvm1Ab
- Contenitore protezione ricarica LiPo Medium (22x18 cm) https://bit.ly/2MojwET
- Contenitore protezione ricarica LiPo Small (10x20 cm) https://bit.ly/2MrjKv3
- Super Fine Detail Brush with 2 Tips (7 mm 9 mm) Modelcraft https://bit.ly/3cuvJmf
- Mr.Crafting Kinfe Mr.Hobby https://bit.ly/2ZGoswV
Vecchio 12-06-20, 12:09 PM   #57
Super Moderatore
L'avatar di gnanni
- Volvo A60S Hauler 6x6 Telaio G6-01 6WD 1:24 Kit Tamiya https://bit.ly/3cF9LxL
- Outback Hi-Rock 4x4 Trail Crawler 4WD 1:10 RTR FTX https://bit.ly/2ML5r4C
- Chernobyl - Radiation Monitoring Station 1:35 ICM https://bit.ly/2Tp15Uz
- Tools 3 1:24 Fujimi https://bit.ly/2YgXUjr
- Tools 2 1:24 Fujimi https://bit.ly/3f7PvFY
- Ferrari Dino 206 GT 1:24 Fujimi https://bit.ly/2UshwzV
- Lamborghini Reventon 1:24 Fujimi https://bit.ly/2MO87hP
- Xuron Photo-Etch Scissors Modelcraft https://bit.ly/2Yooqro
- Angled Screwdriver Bit Holder Modelcraft https://bit.ly/3eZ452q
- Chiave registrazione tiranti Yeah Racing https://bit.ly/2YlNzTz
- Mr.Weathering Set 2 pennelli extra large Mr.Hobby https://bit.ly/3ctfENz
Vecchio 19-06-20, 01:26 PM   #58
Super Moderatore
L'avatar di gnanni
- Comical Avante Telaio GF-01CB 4WD 1:10 Kit Tamiya https://bit.ly/3h5X55z
- Toyota Gazoo Hybrid 2019 Telaio F103GT 2WD 1:10 Kit Tamiya https://bit.ly/2Y6mJjq
- Chernobyl 2 - Fire Fighters 1:35 ICM https://bit.ly/2X5GJ4V
- Saint Malo 1:20 Artesania Latina https://bit.ly/3fwuXae
- North American F-86E Sabre 1:48 Italeri https://bit.ly/30Vv1MD
- Jeep Militare RC 1:10 Verde Radiosistemi https://bit.ly/3hkKfkg
- Mr.Rivet Marking Mr.Hobby https://bit.ly/3713qul
- Xuron Tapered Head Micro-Shear Flush Cutter Modelcraft https://bit.ly/30O8YaN
- Set 5 pinze di precisione Modelcraft https://bit.ly/30Qunju
- Sacchetto graniglia Grigia per massicciata 250 gr HO-TT Noch http://bit.ly/2nEmQDq
- Rete elastica bloccaggio attrezzature su portapacchi Nera 250x150mm x Traxxas TRX-4 Yeahracing https://bit.ly/3fy7sxr
- Trascinatori ruote in alluminio Neri offset +15mm x esagono da 15mm x Traxxas TRX-4 Yeahracing https://bit.ly/2AAlDU5
- Dadi ruote per Setup System in alluminio colore Arancio Yeahracing https://bit.ly/3ftN4xm
Vecchio 26-06-20, 03:05 PM   #59
Super Moderatore
L'avatar di gnanni
- Porsche 934 Vaillant + fotoincisioni 1:12 Tamiya https://bit.ly/3hWZ0d4
- TS102 Spray cobalt green Tamiya https://bit.ly/3fSUfzr
- Ford Mustang SVT Cobra 1995 TT-01E 4WD 1:10 Kit Tamiya https://bit.ly/3drJmD7
- Mini4WD Cosmosonic FM-A Chassis Tamiya https://bit.ly/3fY4lPt
- Mini4wd Supporto posteriore Carbon 1,5 mm Japan Cup 2020 Tamiya https://bit.ly/2VfYZr3
- Mini4wd Supporto freno posteriore Carbon 1,5 mm Japan Cup 2020 Tamiya https://bit.ly/3fOCAZC
- Mini4wd Aluminium Setting Board Brown Japan Cup 2020 Tamiya https://bit.ly/2Cw6PGs
- Taglierino impugnabile con 2 lame Modelcraft https://bit.ly/3hX5EjI
- Set 3 spazzole ottone Modelcraft https://bit.ly/2YXFhRO
- Set 3 spazzole acciaio Modelcraft https://bit.ly/3fUutLo
- Morsa con basetta e impugnatura Modelcraft https://bit.ly/3hTVwYW
Vecchio 03-07-20, 01:00 PM   #60
Super Moderatore
L'avatar di gnanni
- Wild Willy 2 Off-Road 2WD 1:12 Kit Tamiya https://bit.ly/3csoXNI
- Dump Truck Metal Style 4WD telaio GF-01 1:24 Kit Tamiya https://bit.ly/2AkDe29
- Ford Mustang GT4 1:24 Tamiya https://bit.ly/3ePihv3
- MAN TGX XXL Wolf Transporte 1:24 Italeri https://bit.ly/2NLrj0m
- Container Trailer 1:24 Italeri https://bit.ly/2BSo04X
- Start-set Treno Italo elettrico H0 1:87 Lima https://bit.ly/3ifdYeN
- Taglierino retraibile tipo 1 Modelcraft https://bit.ly/2YOYdUj
- Taglierino grip confort tipo 1 Modelcraft https://bit.ly/3dTTIM9
- Mr.Masing Clay Mr.Hobby https://bit.ly/3ds6BwN
- Diluente per acrilici Italeri https://bit.ly/3eQSLWq
- Aqua Color Revell https://bit.ly/2BQBXQJ
modellismo, news, offerte
BB code attivo
Il codice IMG attivo
il codice HTML disattivato
Dubbio su un video di modellismo totonno87 Statico - Kits, Info e Varie 16 04-06-15 12:30 PM
Raccolta video modellismo verrazz0 Off Topic 38 27-11-12 08:04 PM
Video di modellismo cava Off Topic 2 03-05-12 06:46 PM
Primo video sul modellismo markdaan Thunder Tiger 7 07-01-09 08:54 AM
Rendi piu' dinamico il tuo sito... inserisci le news di Modellismo.it gnanni Comunicazioni e presentazioni 3 12-01-07 09:28 AM
Tutti gli orari sono GMT +2. Attualmente sono le 05:36 AM.
Chi Siamo | Pubblicit | Scambio banner | Disclaimer | Regolamento | P.IVA 00319251203
