problemi con i servi .............. mai più con Hitec
La tua macchinina non gira , frena poco , è lenta di sterzo oggi c'è la soluzione 40kg e sei a cavallo
HS-7950TG
Introducing the next generation Ultra performance servos from Hitec. The "Ultra Torque" HS-7950TG features our second generation "G2" programmable digital circuit, Hitec's exclusive Titanium gear set, Heatsink case, and ultra power coreless motor making it arguably THE best R/C servo ever produced!
This new circuit has twice the resolution of our original circuit while adding programmable overload protection. The HS-7950TG has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 403oz./in. of torque at 6.0 volts, all this power is harnessed by incorporating the industries first Titanium gears for incredible wear resistance and two strong hardened steel gear pins and axial brass bushing in the servo case.
Available early 2009.
Detailed Specifications
Motor Type: Coreless
Bearing Type: Dual
Speed: .15
English Metric
Torque: 403 oz
