Vecchio 06-10-08, 12:36 AM   #1
L'avatar di Maxcapo
Maxcapo è un newbie...
Predefinito Info su caricabatterie per Orion
girando su Ebay ho trovato un caricabatterie ma non essendo assolutamente esperto vi chiedo se è adatto a caricare le batterie in mio possesso (1 pacco di 5 celle in linea della Orion Marathon 1.600 per la RX e 8 pile della Orion da 2.700 per la TX)
Le caratteristiche del caricabatterie sono le seguenti:
A>Technical Specification:
Input voltage range: 12V~15V DC
Power Supply: Input voltage: 100V~240V
Output voltage: 12V
Output current: 5A
Dimension: 55mm x33mm x109mm
Weight: 218g
Selectable output current: 500ma, 700ma, 900ma, 1100ma for choice
Battery repair current: 120ma
Recommended charging rate: 1C ( Max)
Battery type and number: Li-Poly battery pack with 2~4 cells
Ni-MH battery pack with 1~9 cells
LCD display: 4x32 characters
Dimension: 94mm x140mm x41.5mm
Weight: 239g
B>Main Functional Features:
1) Free charge option of Li-Poly battery or Ni-MH battery:
The smart charger is capable of parallel charging Li-Poly battery pack and series charging Ni-MH battery pack.
2)Charge Time Control:
Charge time can be manually set. When the fixed time is reached, battery charging will terminate automatically. (Default setting is 3 hours)
3)Selection of Terminated Charge voltage:
3 types of terminated charge voltage can be chosen, 4.15V, 4.25V, 4.35V (Default setting is 4.15V)
4)Charge Current Setting:
The charger has four segments of charge current for choice, 500ma, 700ma, 900ma, 1100ma. (Default setting is 500ma)
5)Selection of cells count:
In Li-Poly mode, cell number is 2~4 and in Ni-MH mode, cell number is 1~9. (For Li-Poly pack, if the number is not selected, the charger will sense the number of cells automatically).
6)Protection from battery reverse:
When battery pole is connected incorrectly, the charger will give an alarm. Meanwhile, the LCD indicator will show "BATTERY REVERSE" and the position of the reversed battery.
7)Automatically battery repair:
If an over discharged battery with exceedingly low voltage is charged with ordinary current, the battery may be unrepairablly damaged. The smart charger can automatically sense voltage of each cell when a Li-Poly battery pack is connected. If an over discharged battery (voltage is lower than 2.4V) is detected, the charger will intelligently charge the over discharged battery with smaller current. And when the voltage of the over discharged battery has reached 2.4V, the charge current will turn into ordinary current to continue charging it.
8)Identification of bad battery:
When charging a Li-Poly battery pack, if one cell or several cells are damaged, the smart charger will automatically give an alarm, indicate "BATTERY BAD" and stop charging.
9)Indication of full charge:
When the battery voltage has reached the final safety protective charge voltage or the fixed charge time is over, the charger will automatically stop charging, give an alarm and show "CHAGE OK" on the LCD.
10)Function of LCD indication:
a>Set and indicate charge battery type, Li-Poly or Ni-MH
b>Set and indicate charge time (counting down)
c>Set and indicate charge voltage (4.15V, 4.25V, 4.35V). The LCD indicator will show dynamic charging voltage of each Li-Poly battery and the Li-Poly battery pack, and the static voltage when full. For Ni-MH battery, the LCD indicator will show dynamic voltage of series charge and static voltage when full.
d>Set and indicate charge current (500ma, 700ma, 900ma, 1100ma). The LCD indicator will show charge current of each Li-Poly battery or series charge current of Ni-MH battery.
e>Set and indicate number of cells (2~4 cells for Li-Poly battery, 1~9 cells for Ni-MH battery)
f>Indicate "BATTERY REPAIR" when the battery in repair and show the position and number of the repairing battery, whose repair current, will be shown separately.
g>Indicate "CHARGE OK" when the pack has been fully charged.
h>Indicate "BATTERY REVERSE" when battery poles are incorrectly connected and show the position of the reversed battery.
i>Indicate "BATTERY BAD" when sense a bad battery and show the position and number of the bad batteris.
11)Buzzer Indicator:
Under such conditions: starting the charger, setting, battery reverse, identifying bad battery and full charge, buzzer indicator will sound.
C>Operation Instruction:
1)Button Function
*Select Button: By pressing this button, the user can choose the following items:
a)Selection of Li-Poly battery pack or Ni-MH battery pack. Default setting is Li-Poly battery pack.
b)Selection of charge time, default setting is 3 hours
c)Selection of safety charge voltage, default setting is 4.15V
d)Selection of charge current, default setting is 500ma
e)Selection of battery count. The smart charge can automatically sense Li-Poly battery count. In Ni-MH mode, the user has o input cell numbers.
*Set Button: By pressing this button, the user can set the following items:
a)Set Li-Poly mode or Ni-MH mode
b)Set charge time: hour setting: 0~9; minute setting: 5 min one step
c)Set safety charge time: 3 types of selectable charge voltage can be chosen, 4.15V, 4.25V, 4.35V. Not suitable for Ni-MH battery.
d)Set charge current: 4 steps of selectable charge current, 500ma, 700ma, 900ma, 1100ma
e)Set battery count: 2~4 cells Li-Poly battery pack, 1~9 cells Ni-MH battery pack
*Enter Button: After each setting, b pressing this button, the user can confirm the messages entered into the charger.
*Start/Stop Button: Press this button to start charging when all the settings are finished. After starting, further press of this button will stop the charger. If battery pack is correctly connected after starting the deice, directly press of Start/Stop button will immediately start charging (for Li-Poly battery pack connected into parallel port only).
2)Charge under default settings:
Only for 2~4 cells Li-Poly battery pack (we take 3 cells of 11.1v for an example)
Connect the power source, adaptor and Li-Poly pack correctly, LCD screen will display as photo (sorry no photo available here). Press the start button, after a click sound, the charger starts working. Default setting of time is 3 hours and start counting down. Default settings of voltage is 4.15V, current is 500ma and number of cells is 3. During the process of charging, voltage and current of each cells and the total voltage of the battery pack will be shown by turning on the LCD screen as photo (xx). When one cell of the battery pack reaches the final voltage, the full cell with stop charging and charge current of it will be "0" on the LCD screen. Other cells continue charging until all cells reach the fixed voltage (4.15V), and the process of charging is finished. LCD screen will indicate full charge and the total voltage of the battery pack as photo (xx) Buzzer indicator will sound several times to remind the user of full charge.
3)Charge under manual settings
3-1 Li-Poly battery pack (parallel charging)
Connect the power source, adaptor and Li-Poly battery pack correctly according to the connection sketch map (we take 3 cells of 11.1v for an example). First press "Select" button, "Li" will be shown on the upper right corner of the screen. On the second line is "parallel". Further press of "Select" button is for charge time setting, which should be set according to battery capacity and charge current. Press "Enter" button to confirm setting. Another press of "Select" button is for charge voltage setting. Press "Set" button to set safety charge voltage. (Commonly set 4.15V or 4.25V, 4.35V is not recommended except when battery manufacturer specially marked). Press "Select" button again to set charge current, which is supposed to be set according to battery capacity. Press "Enter" button to confirm setting. Warmly recommendation: If you are not engaged, small current is suggested to efficiently extend battery service life. Having finished setting charge current, press "Select" button for the last item --- battery count, which should be set according to the number of cells connected. Press "Set" button to choose cell number and press "Enter" to confirm. (For parallel charged Li-Poly battery, the micro-processor can automatically sense and display cell count). So far, all function have been set. Then press "Start/Stop" button to start charging. The charger will work according to the parameter fixed.
3-2 Ni-MH battery pack (series charging)
Connect the power source, adaptor and Li-Poly pack correctly according to the connection sketch map. First press "Select" button, "Li" will be shown in the upper right corner of the screen. Press "Set" button to choose ¡°Ni-MH¡±. The second line reads "series". Further press "Select" button is for charge time setting, which should be set according to battery capacity and charge current. Press "Enter" button to confirm setting. Press "Select" button to jump over voltage setting, which is not necessary for Ni-MH charge. Press "Enter" button to confirm setting. Press "Start/Stop" button to start charging under the fixed data.
Grazie.
Ultima modifica di Maxcapo : 06-10-08 alle ore 02:53 AM.
Maxcapo non è connesso
Rispondi citando
Adv
Vecchio 07-10-08, 10:49 AM   #2
mimis83 è un newbie...
Predefinito
ma un link no???... consiglio: posta marca e modello de caricabatterie e metti il link...
mimis83 non è connesso
Rispondi citando
Vecchio 07-10-08, 01:50 PM   #3
L'avatar di Maxcapo
Predefinito
Hai ragione...ecco il link
MICROCOMPUTER CARICA BATTERIE LIPO E NI-MH DISPLAY
Rispondi citando
Vecchio 07-10-08, 06:06 PM   #4
Predefinito
Citazione:
Originalmente inviato da Maxcapo Visualizza messaggio
non pare male soprattutto perché va anche con la corrente di casa... non è una marca conosciuta e questo mi fa un pò pensare... vei un pò tu...
Rispondi citando
Vecchio 08-10-08, 10:10 PM   #5
L'avatar di babyfurious2
babyfurious2 è un newbie...
Predefinito
mi pare una cinesata sulla base del vecchio turbothirty....
Cerca qualcosa di più conosciuto, di marca, e sicuramente più sicuro...
Modellismo Fioroni
babyfurious2 non è connesso
Rispondi citando
Vecchio 10-10-08, 03:11 AM   #6
L'avatar di Maxcapo
Predefinito
Modellismo.it
questo forse è meno cinese dell'altro....
Rispondi citando
Vecchio 10-10-08, 04:55 AM   #7
L'avatar di Maxcapo
Predefinito
Grazie per il consiglio siete come sempre GRANDI !!!
Scarto il cinese e mi butto su qualcosa di serio.
Rispondi citando
Vecchio 10-10-08, 02:31 PM   #8
Predefinito
Modellismo.it
questo è l'ideale... lo si trova anche a meno...
Rispondi citando
Vecchio 11-10-08, 03:16 AM   #9
L'avatar di Maxcapo
Predefinito
il Multiplex che mi hai indicato mi sembra un ottimo caricabatterie...l'unico problema è che dovrei anche prendere un alimentatore da almeno 10A. quindi in totale vado sui 100 euro se mi dice bene.
Il mio budget per caricare le pile TX e RX è 50 euro quindi avevo visto questo caricabatterie a 220V della Prolux:
Codice: P3672- Prezzo: €49.00
Ultrapeak-LCD - Carica-Scarica Batterie computerizzato 12V-220V 4-8 celle a 220V 0,5-2A - 4-7 Celle 12V 0,5-4A.
Dotato di ampio display LCD, permette di caricare e scaricare batterie al NiCd e NiMh.
Collegato alla rete 220V AC, carica e scarica batterie da 4 a 8 celle con corrente da 0,5A a 2A.
Collegandolo ad un alimentatore esterno da 12V 5A (min), carica e scarica batterie da 4 a 7 celle con corrente da 0,5 a 4A.
L'ampio display permette di impostare i tempi e le correnti di carica e scarica con segnalazione acustica di fine ciclo.
Caratteristiche:
- Ingresso: 100V-220V AC 50/60Hz o 12V DC
- Uscita: 4-8 celle a 220V 0,5-2A o 4-7 Celle 12V 0,5-4A
- Controllato da microprocessore a 12 bit
- Segnalazione acustica di fine ciclo
- Protezione contro i corto circuito e inversione di polarita'
Mi rendo conto che non è il massimo ma considerando che devo ancora prendere Radio 2.4GHz (devo scegliere tra DX3R, DX2.0 e Acoms Tech...più che scegliere trovare un occasione nuova o usata), 2 servi decenti da +10kg, Pile TX e RX, un centinaio di euro da Fioroni di pezzi motore....alla fine credo che ora mi devo accontentare di un caricabatterie modesto come il Prolux.
Grazie comunque per il consiglio e ditemi cosa ne pensate.
Rispondi citando
Vecchio 13-10-08, 06:41 PM   #10
Predefinito
questa mi pare una scelta già migliore.... naturalmente ha i suoi limiti ma per lo meno non è una cinesata... ti consiglio di comprarti una serie di connettori e adattatori...
Rispondi citando
Vecchio 14-10-08, 10:39 PM   #11
L'avatar di axxel
axxel è un newbie...
Invia un messaggio via MSN a axxel Invia un messaggio via Yahoo a axxel
Predefinito
io uso questo,costa un botto ma credimi e' grande ...funzia a 220 e 12 e questo ti fara' comodo !!!
EX 15 PRO 20A
AMBImodel
Citazione:
Caratteristiche:
axxel non è connesso
Rispondi citando
Strumenti discussione
Regole messaggi
Tu non puoi replicare
Tu non puoi inviare allegati
Il codice BB è Attivato
Le faccine sono Attivato
Il codice [IMG] è Attivato
Il codice HTML è Disattivato
Trackbacks are Attivato
Pingbacks are Attivato
Refbacks are Attivato
Discussione Autore discussione Forum Risposte Ultimo messaggio
servi VORTEX-TEAM ORION angelokanay Impianti radio ed elettronica 7 24-09-08 11:37 AM
Orion wasp da off 21 babyfurious2 Automodelli a scoppio 1/8 Off Road 7 09-04-08 10:43 PM
GOMME ORION X 1/18 carlomagno Mini automodelli radiocomandati 0 21-08-06 10:49 AM
motore orion v2 tb02 Automodelli elettrici 4 04-04-06 02:16 PM
Com'è il Team Orion Elite ??? supermg Mini automodelli radiocomandati 6 05-01-05 11:58 PM
Tutti gli orari sono GMT +2. Adesso sono le 08:32 AM.
Powered by linux
