Overview
30% faster and 0.5 oz (15 g) lighter than the 4PKS-R.
3.5" (89 mm) QVGA (Quarter Video Graphics Array) TFT (Thin Film Transistor) color LCD screen makes navigation and programming fast and simple.
Three grip choices (two are optional).
Durable, long-life wheel potentiometers.
Two durable, throttle trigger options with tension adjustments.
Large, assignable switch that can be touched by a driver's body is located on the bottom edge of the transmitter.
Low steering wheel position with drop-down option.
Steering wheel can be switched for left-handed drivers.
Trigger unit can be adjusted forward or backward by 7 mm.
Compatible with these T-FHSS, S-FHSS and FASST receivers: R304SB, R304SB-E, R614FS, R614FF-E, R2104GF, R204GF-E, R203GF and others as they are developed.
31 telemetry sensor slots available (sensors sold separately).
Synthesized voice for telemetry data.
Multiple crawler functions — including 4WS mixing and Dual ESC mixing.
Comfortable feel/balance.
Internal aluminum frame.
5 programmable mixes.
40-model memory.
Steering mixer.
Brake mixer.
Gyro mixer.
CPS (Channel Power Switch) mixer.
Tilt mixer.
Adjustable dual-compound steering wheel can be switched around for a different feel.
Multi-function jog switch.
Grip with built-in vibration.
Built-in S.Bus servo/Futaba ESC/telemetry sensor programmers.
Mechanical ATL.
32° and 34° wheel adapters.
"Telemetry Disabled" LED indicator.
Earphone jack.
Battery charging jack.
Built-in speaker.
Adjustable rotating antenna.
Compatible with 2S LiFe batteries, NiMHs, dry cells and other battery options. Lasts approximately 10 hours in T-FHSS mode and approximately 6 hours in FASST mode using a LiFe battery.
Micro memory card slot.
Free user-updateable software.
Push-button power switch with auto-off function.
Clock and voltage meter.
Neck strap holder.
