Vecchio 10-10-19, 08:40 AM   #1
L'avatar di lukappaseidue
Registrato dal: Dec 2016
residenza: Catania
lukappaseidue inizia ad ingranare.
predefinito Hubsan Zino Pro. GPS - WiFi - 4km range - 4k30p gimbal
https://www.hubsan.com/eur/index.php...roducts_id=668
Nell'attesa che venga distribuito ecco alcune specifiche (in neretto le differenze con la versione standard)
Brand Name: Hubsan
Item Name: ZINO PRO
Drone Size: 304.6*252.4*90mm (Unfolded)
187*104*90mm (Folded)
Controller Size: 157.8*40*75mm
Motor: Brushless Motors
GNSS: GPS+GLONASS
Flying Weight: 700g
Drone Battery: 11.4V 3000mAh (Included)
Charging Time: around 180 Minutes
Transmitter Battery: 3.7V 2600mAh (Included)
Flight Time: 23 minutes
Flight Distance: 4KMS
Transmission Distance: 4KMS
Camera: UHD 4K, Ambarella A12S chip,1/3 inch sony sensor
Gimbal: 3-Axis (removable lens)
Video Ressolution: 3840 X 2160 30FPS
FPV: HD WI-FI video transmission
APP: X-HUBSAN APP
Micro SD card (not included): Support class10, 16G-64G
Features:
- Foldable structure. Simple and portable.
- 3-axis gimbal&4K HD resolution, panorama photography.
- Removable Lens, can be equiped with filters.
- Image Tracking. Capture every moment.
- Line Fly Mode. Precise and convenient,fly in a straight line.
- Vision Auxiliary Landing. When landing,the drone searches the apron automatically and lands on it precisely.
- Orbiting. Set orbit center and fly around the center point.
Function: GPS+GLONASS, Vision Auxiliary Landing, Orbiting, Image Tracking, Automatic Takeoff/Landing, Automatic Return Home, Low Power Failsafe Mode, Flight Control Failsafe Mode, 4K UHD Camera, Detachable Filter
Hubsan Zino Pro. GPS - WiFi - 4km range - 4k30p gimbal-hubsan-zino-pro-recensione-e-prezzo-800x445.png
Ultima modifica di lukappaseidue; 10-10-19 a 08:43 AM
lukappaseidue non è in linea   Rispondi quotando
Vecchio 10-10-19, 08:44 AM   #2
residenza: Catania
Vecchio 10-10-19, 08:49 AM   #3
residenza: Catania
Vecchio 10-10-19, 08:50 AM   #4
residenza: Catania
Vecchio 31-10-19, 12:35 AM   #5
residenza: Catania
Vecchio 31-10-19, 03:56 PM   #6
residenza: Catania
Impressioni sull'unboxing
A primo impatto, non so se effetto placebo, ho la sensazione di maggiore solidità sia del drone che del radiocomando: soprattutto gli stick mi sembrano meno giocattolosi.
Altra cosa che ho notato subito è la scomparsa, sul radiocomando, tanto dei pin da ponticellare che dell'interruttore, per effettuare l'aggiornamento. Adesso l'operazione si potrà eseguire da applicazione.
Altra cosa interessante è l'introduzione di una ventola all'interno del drone, per il raffreddamento attivo: è pure cambiata la musichetta di avvio.
La batteria mi sembra la stessa, quanto meno le caratteristiche di amperaggio e tensione (LiHV)
Per il resto mi sembra che sia tutto uguale allo Zino Standard
A breve seguiranno ulteriori test e soprattutto il più atteso .... rimanenete sintonizzati e, iscrivetevi al canale, un LIKE e selezionate la campanella per restare aggiornati ad ogni nuovo video (e ne arriveranno altri)
Ragazzi, fatto il primo volo con HUBSAN ZINO PRO!!!!!
Sono rimasto davvero molto ma molto impressionato .... positivamente.
Prima notizia IMPORTANTISSIMA. sono stato in volo per oltre i 23 minuti dichiarati: senza considerare i tempi di ottimizzazione e di controllo (preflight check) nonchè calibrazioni: in merito a quest'ultimo punto osservo che ho avuto difficoltà nella calibrazione geomagnetica. Dovuta fare almeno 3 volte (abnormal geomagnetic ....)
NESSUNA DISCONNESSIONE!!!!!!
Ovviamente farò un video con sull'autonomia di volo .... al momento soddisfattissimo:
Altra cosa interessante: finalmente funziona il tasto SPORT: Adesso in normal arriva a circa 8 m/s e in sport ha toccato punte di 11.1 m/s
Ambito fotografico. Noto dei percettibili miglioramenti .... e IL BITRATE DEI VIDEO E' A 55MB
I comandi li trovo meglio del precente ZINO standard, ma ancora perfettibili, soprattutto la rotazione sull'asse orizzontale, ancora troppo nervosa nonostante abbia abbassato la sensibilità
P.S. Ho abbondantemente superato i limiti del precedente ZINO standard senza difficoltà
Vecchio 03-11-19, 01:20 AM   #7
residenza: Catania
in test sull'autonomia di volo di questo nuovo gioiellino in casa HUBSAN
Lo ZINO PRO
Vecchio 16-11-19, 08:11 PM   #8
residenza: Catania
Assistenza Hubsan zino JJ_Evolution Droni - Multirotori 4 08-07-21 12:19 PM
hubsan zino: problemi scaricare foto e video sanlau Droni - Multirotori 2 25-09-19 09:33 PM
Downgrade Firmware fotocamera Hubsan zino JJ_Evolution Droni - Multirotori 2 29-07-19 04:10 PM
HUBSAN H117S Zino: il nuovo drone pieghevole di HUBSAN lukappaseidue Droni - Multirotori 12 13-03-19 12:14 PM
[RECENSIONE] Hubsan ZINO è un BUON DRONE ma.. michele990 Droni - Multirotori 3 16-12-18 01:38 AM
Tutti gli orari sono GMT +2. Attualmente sono le 06:06 PM.
