In effetti sul manuale c'è un piccolo errore....
4-9 Cells NiMH or 2-3 Cells Li-Po
1) For 4-6 cells NiMH or 2 cells Lipo: You needn’t change the fan combined with the ESC;
2) For 7-9 cell NiMH or 3 (non 2) cells Lipo: You must change the fan combined with the controller
because it cannot work with such a high voltage, so please choose a high voltage fan or supply the fan from the receiver (+5V);
【OPTIONAL ACCESSORIES FOR UPGRADE】
We provide the following optional accessories for upgrade your power system:
1. Cooling fan (12V): The high voltage fan is necessary when you are using battery pack more than 6 cells of NiMH. It is located on the heat sink of the ESC, it helps to cool the ESC with downward airflow. The picture on the right side shows the installation.
WARNING! Please note the original fan (5V) combined with the ESC can
ONLY work with a 2 cells lithium battery pack or 4-6 cells NiMH battery pack.
Please NEVER use it with a 3 cells lithium battery pack or NiMH battery pack more than 6 cells, otherwise it may be destroyed.
Please check the label of the fan carefully to confirm its working voltage
before using it.
La ventola da te postata dovrebbe andare bene
